EG rear LCA's on EF?
Old Jan 18, 2007 | 12:01 PM
DmcL's Avatar
Default EG rear LCA's on EF?
whats the difference between aftermarket ones meant for an EF (if there are any) and ones meant for an EG but fitted to an EF? little more camber or something?
mattminer's Avatar
Default Re: EG rear LCA's on EF? (DmcL)
EG and EF LCAs are identical.
-M@
Old Jan 18, 2007 | 12:06 PM
CWBETB's Avatar
Default Re: EG rear LCA's on EF? (mattminer)
Yes they are the same but might have different sway bar mounting locations. Aftermarket LCA's usually list as same part number "I just ordered Function 7s"
Old Jan 18, 2007 | 01:27 PM
1slowEF9's Avatar
EF, EG, and DC are pretty much all interchangable for rear LCA's so you can even put EG suspension on the rear and front. But you need EG/DC front forks to mount the struts. I have suspension off my old EG on my EF
Nex 1 piece coilovers/struts and omni Lca's worked perfect on my lil hatch and its all off a EG
Try reading the FAQ thread on the 1st page at the top. It is VERY imformative and you will learn alot
Old Jan 18, 2007 | 04:36 PM
sirtef9's Avatar
Default Re: (1slowEF9)
i did the eg rear brakes, i had to use my ef rear locater arm though, the eg's are shorter and it will point your rear tires in alot..
Old Jan 18, 2007 | 04:40 PM
dr_latino999's Avatar
Default Re: (sirtef9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirtef9 &raquo;</TD></TR><TR><TD CLASS="quote">i did the eg rear brakes, i had to use my ef rear locater arm though, the eg's are shorter and it will point your rear tires in alot..</TD></TR></TABLE> What are you talking about, the compensator arm? And you realize there are two different degrees of freedom in saying "point your tires out"
Old Jan 18, 2007 | 04:44 PM
sirtef9's Avatar
Default Re: (dr_latino999)
whatver u wanna call em, you know what im talking about, and it toes in like 2 inches, dont try and talk me down cuz im a noob, Just offering my knowledge to him
Old Jan 18, 2007 | 04:45 PM
sirtef9's Avatar
I also said pointed in *****, so whats that mean to you?
Old Jan 18, 2007 | 05:07 PM
Hakasniodhao's Avatar
I may be putting eg suspension in my rex, good to know the lcas are interchangeable too :D
Old Jan 18, 2007 | 05:46 PM
1slowEF9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirtef9 &raquo;</TD></TR><TR><TD CLASS="quote">I also said pointed in *****, so whats that mean to you? </TD></TR></TABLE>
he called you a ***** HAHAHAHAHA who says that?
Joericci46
May 12, 2018 06:34 PM
724chris
Feb 28, 2011 02:01 PM
hb_guy
Nov 7, 2005 08:51 PM
VSM EXtasy
May 6, 2005 05:58 PM
SiccMonkey
Oct 6, 2004 03:54 AM
