MA Audio HK65 will they fit?
Old Jan 18, 2007 | 11:31 AM
doggworld1233's Avatar
Default MA Audio HK65 will they fit?
i want to know if these 6.5 speakers will fit my car and if anyone has them. i have a 95 civic coupe ex. and right now i have some 5.25 in the doors with the black thingy. i was told that 6.5 would fit.
justin
the speakers i want to put are MA Audio HK65
Old Jan 18, 2007 | 11:32 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: MA Audio HK65 will they fit? (doggworld1233)
Yes but you will have to cut the basket. Or make a baffle board or rings.
Old Jan 18, 2007 | 11:45 AM
why and how? i dont understand
Old Jan 18, 2007 | 12:19 PM
fcm's Avatar
fcm
Old Fart
Default Re: (doggworld1233)
A 95 Civic uses standard 6.5" speakers that are no deeper the 2" I believe the MA Audio speakers are an over-sized 6.5", [not sure, can't find any info on them] so the mounting diameter will be more then the standard 5", it is also deeper the 2", meaning the stock speaker housing will have to be modified as wrx-killer-Sti eater mentioned, or a depth reducing ring, [spacer] will have to be used,
Do you have a link for the speakers specs or can you tell us what the mounting depth and mounting diameter is? 94
Old Jan 18, 2007 | 04:21 PM
what do you recomend that is a good speaker in the same price range? that will fit
Old Jan 18, 2007 | 04:29 PM
mounting depth is 2.8
Old Jan 19, 2007 | 07:05 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doggworld1233 &raquo;</TD></TR><TR><TD CLASS="quote">what do you recomend that is a good speaker in the same price range? that will fit</TD></TR></TABLE> What is the price range?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doggworld1233 &raquo;</TD></TR><TR><TD CLASS="quote">mounting depth is 2.8
</TD></TR></TABLE> What is the mounting hole diameter?
You should have no problem getting the extra .8" of depth by cutting a hole big enough for the magnet in the back of the stock plastic speaker housings, but you may still have to deal with the actual mounting of the speaker if it is not a standard 6.5" speaker, let me ask you this, how many mounting holes does the speaker have? 94
Old Jan 19, 2007 | 07:20 AM
fcm's Avatar
fcm
Old Fart
Default Re: (fcm)
NM the question about mounting holes, it uses the "Euro" type basket, chit load of holes... http://www.onlinecarstereo.com...14722 and according to the above they are 2.75" deep, bu no mention of mounting hole diameter.
DOH! here's one that say they are 2.5" deep... http://www.sonicelectronix.com/item_2687.html 94
Old Jan 19, 2007 | 07:45 AM
so it will fit?
Old Jan 20, 2007 | 07:42 AM
fcm's Avatar
fcm
Old Fart
Only if mounting diameter hole is 5", it should say what diameter the cutout is supposed to be, or measure the speaker itself, what is the diameter of the basket at the first "step" after the speakers "mounting lip", [part mounting with holes in it]?94
Old Jan 22, 2007 | 03:26 PM
what is a good speaker that i can get that would be around $50 that will fit
Old Jan 22, 2007 | 05:01 PM
fcm's Avatar
fcm
Old Fart
Well I am not sure good and $50 speakers can be used in the same breath, but you may find a set of Pioneer, or Infinitys on eBay. 94
greazy_fox
Mar 21, 2009 12:16 PM
spacin
Audio / Security / Video
Jul 13, 2007 09:27 PM
baaba2007
Honda Fit
Mar 12, 2007 06:21 PM
$amGD3
20
Jul 22, 2005 03:27 PM
Unjockable
12
Dec 15, 2003 10:22 AM
