3500 rpm false rev limiter wtf?
Old Jan 18, 2007 | 10:07 AM
littlefella's Avatar
Default 3500 rpm false rev limiter wtf?
ok ive built at least a hundred swapped out cars and havent encountered this problem yet #4 was just dumping raw fuel wouldnt even hit (changed ecu fixed miss)1 down but still 3500 rpm limit btw its a 93 civic ex with a ls swap,changed distributor, no different, checked injector wiring , its cool, checked map,tps, any ideas guys ? WTF?
smart *** replys not welcome!
Old Jan 18, 2007 | 11:04 AM
JDM_dreamer's Avatar
Default Re: 3500 rpm false rev limiter wtf? (littlefella)
possible the ecu has a 2 step rev limiter? maybe there is a MSD box stashed under the dash lol
hey, ya never know..
Old Jan 18, 2007 | 11:37 AM
sol2hatch's Avatar
your car is in limp mode. It runs the engine rich and puts a rev limiter at about 3500 to keep from messing up your engine. You probably have a code too.
Old Jan 18, 2007 | 02:13 PM
pennies_hatchie's Avatar
Default Re: 3500 rpm false rev limiter wtf? (sol2hatch)
exactly, its in limp mode. i would check the wiring with the dizzy. i remember when i swapped a d16y8 into an eg and i redid the wires for the dizzy. well it was completely wrong and the motor was dumping fuel out of the headers. but i had a cel, so check that if you have one on
Old Jan 18, 2007 | 08:44 PM
oneoffaccord's Avatar
Default Re: 3500 rpm false rev limiter wtf? (pennies_hatchie)
Your ecu took a ****. i had the same problem with my p14 in my accord. changed the ecu and it works normally.
Old Jan 18, 2007 | 09:36 PM
sol2hatch's Avatar
Default Re: 3500 rpm false rev limiter wtf? (oneoffaccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oneoffaccord &raquo;</TD></TR><TR><TD CLASS="quote">Your ecu took a ****. i had the same problem with my p14 in my accord. changed the ecu and it works normally.</TD></TR></TABLE>
whoa dude, hold on there. You cant just make such bold assumptions. That might have been the case for you, but there are alot of other reasons his car would do what it is doing.
Old Jan 26, 2007 | 03:38 PM
ok well im not new to this guys,i have tried 3 known good ecu's and changed/replaced everything on the engine, the timing is right , o2 sensor ,tps,map,iat fit, alternator,injectors,fuel filter fuel ,pump,distributor,pgmfi main relay,checked codes,throttle body gasket,plugs, wires, cap, button,iac,you should see what a cherry red cat looks like!running real lean,adjusted valves, only thing i can figure is that there is some homo-wiring under the dash.
wtf wtf wtf wtf wtf wtf wtf wtf wtf wtf WTF! BY THE WAY THE CAR RAN FINE WITH THIS SWAP IT IS NOT IN THE SWAP ITSELF ACTUALLY OUTRAN A COUPLE VW'S
Old Jan 26, 2007 | 03:55 PM
THC07's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oneoffaccord &raquo;</TD></TR><TR><TD CLASS="quote">Your ecu took a ****. .</TD></TR></TABLE>
you say you tried more then one ecu?. limp mode is either bad ecu, bad program, bad grounds.
Old Jan 26, 2007 | 04:00 PM
Sloshy's Avatar
last time this happend to my car it was the temp. sensor on the side of the head, But i did get a code for that, and i think you already stated that you dont have any codes..
Old Jan 26, 2007 | 04:08 PM
Default Re: (hatch-E-vanish)
NO CODES. ALL FACTORY GROUNDS IN TACT AND TIGHT GOOD BATTERY CONNECTION 4 ECUS NOW, 1 OUT OF MY OWN DAILY DRIVEN CAR, OK NO MORE REV LIMITER BUT STILL WONT REV FOR ****, ANY THROTTLE AND IT JUST BOGS LIKE HELL,LIKE IT IS NOT GETTING ENOUGH FUEL OR TOO MUCH AIR PRETTY WELL THE SAME THING EITHER WAY POSSIBLY RICH, BUT NO BLACK SMOKE AT ALL SOMETHING IS FUKNWACKY!
Modified by littlefella at 8:19 PM 1/26/2007
Old Jan 27, 2007 | 12:27 PM
sol2hatch's Avatar
Default Re: (littlefella)
DONT TYPE IN ALL CAPS OR I WILL E-KICK YOU IN THE NUTS!!! Its annoying as hell.
Anyway, I am surprised your not throwing a cel. Make sure that your cel light in the dash is even there, some people will take that bulb out to mask any problems before selling a car. Just a thought, its happened before.
Old Jan 27, 2007 | 12:35 PM
EJgsr's Avatar
bump i have the same problem with a GSR swap...
Code 4
Old Jan 27, 2007 | 12:38 PM
SE3Pimp's Avatar
Default Re: 3500 rpm false rev limiter wtf? (USDMej1)
did you check the firing order on the distributor and properly match it with the cyl's? something stupid like that will cause this, always think small first.
Old Jan 27, 2007 | 12:46 PM
EJgsr's Avatar
Default Re: 3500 rpm false rev limiter wtf? (EndlessDc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EndlessDc2 &raquo;</TD></TR><TR><TD CLASS="quote">did you check the firing order on the distributor and properly match it with the cyl's? something stupid like that will cause this, always think small first.</TD></TR></TABLE>
it runs perfect till 3500
Old Jan 27, 2007 | 01:38 PM
Cvic90's Avatar
Make sure the spring on the tip of the coil in the dizzy is there.
EJgsr's Avatar
Default Re: 3500 rpm false rev limiter wtf? (Cvic90)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cvic90 &raquo;</TD></TR><TR><TD CLASS="quote">Make sure the spring on the tip of the coil in the dizzy is there.</TD></TR></TABLE>
its there.
Jabbito
Nov 8, 2015 03:24 PM
shadowgeist
Jan 2, 2014 03:24 PM
97gsrki
Sep 28, 2007 06:17 AM
SohcVtecCrix
Sep 14, 2002 07:23 AM
