losing/leaking oil
Old Jan 18, 2007 | 10:05 AM
vlc92189's Avatar
Default losing/leaking oil
Hey guys ive searched.. but tryna get the exact problem i have.. can oil be leaked out from the head gasket? also around the distributor and cam saels oil is leaking too. my block code where its stamped b18c has oil all over it.. and it looks like its coming from the headgasket and dist. and cam seals.. so can headgassket leak oil?
Old Jan 18, 2007 | 10:44 AM
-HONDA-'s Avatar
i have the same problem as well!
Old Jan 18, 2007 | 02:04 PM
vlc92189's Avatar
Default Re: (-HONDA-)
bump anyone?
Old Jan 18, 2007 | 02:08 PM
99redSIR's Avatar
Default Re: (vlc92189)
i got same problem..
my piston rings are shot.
and i think were all leaking oil from Vtec Soleniod.
i gotta add 2 quarts a week now for oil..
Old Jan 18, 2007 | 02:10 PM
alacard's Avatar
Default Re: (99redSIR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99redSIR &raquo;</TD></TR><TR><TD CLASS="quote">i got same problem..
i gotta add 2 quarts a week now for oil.. </TD></TR></TABLE>
2 quarts a week??? thats crazy. you should fix that asap.
anyways, bump for some help for you guys
Old Jan 18, 2007 | 05:49 PM
vlc92189's Avatar
i think my rings are shot too.. other day i looked at the oil and i didnt even see any on the dipstick :-/ but its been fine now.. anyone else?
Old Jan 18, 2007 | 06:05 PM
Chim Chim's Avatar
pictures would help...
If your rings are shot, you'd probably see bluish black smoke coming out of your exhaust since you'd be burning oil... Try replacing your distributor o-ring and throwing some hondabond on the mating surface of the v-tec solenoid. You can also check your valve cover gasket as that would be more likely to leak oil before the head gasket...
Old Jan 18, 2007 | 07:10 PM
byronl's Avatar
Default Re: losing/leaking oil (vlc92189)
replace your distributor o-ring, vtec solenoid gasket, and your cam seals. Then see if it still leaks oil when u change those.
Old Jan 18, 2007 | 07:29 PM
Jimmy's Avatar
Global Moderator
Default Re: losing/leaking oil (byronl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by byronl &raquo;</TD></TR><TR><TD CLASS="quote">replace your distributor o-ring, vtec solenoid gasket, and your cam seals. Then see if it still leaks oil when u change those.</TD></TR></TABLE>
Yeah most likely one of the above listed..
Old Jan 18, 2007 | 09:19 PM
GerryL's Avatar
Check your PCV valve. A defective PCV system will allow pressure build up which will result in oil leaks.
Old Jan 19, 2007 | 09:05 AM
vlc92189's Avatar
Default Re: (GerryL)
cool thanks guys much appreciated.
Lauj87
Apr 4, 2007 07:50 PM
vi3tromanc3r
Jan 23, 2007 09:45 PM
DAintegraGSR
Apr 28, 2005 08:22 PM
deepnite
Oct 9, 2002 01:46 PM
