MY SEDAN PULLS RIGHT? DONT KNOW WHATS WRONG.... PLEASE HELP
Old Jan 18, 2007 | 08:01 AM
MHSD's Avatar
Default MY SEDAN PULLS RIGHT? DONT KNOW WHATS WRONG.... PLEASE HELP
WELL A WHILE AGO I PUT MY FRIENDS ROTAS ON JUST TO SEE HOW THEY LOOK. AND NOW THAT I HAVE PUT MY STEELIES BACK ON THE CAR PULLS TO THE RIGHT... THE CAR IS COMPLETLY STOCK
Old Jan 18, 2007 | 08:22 AM
ryan89crx's Avatar
turn caps lock off
Old Jan 18, 2007 | 08:23 AM
MHSD's Avatar
Default Re: MY SEDAN PULLS RIGHT? DONT KNOW WHATS WRONG.... PLEASE HELP (LONGLIVETHEEF)
SORRY I FORGOT TO ADD THAT I DID CUT THE SPRINGS I DIDNT KNOW IF THAT WOULD MEAN ANYTHING... BUT OTHER THAT....STOCK MOTOR STOCK EVERYTHING..
Old Jan 18, 2007 | 08:37 AM
fireant's Avatar
the most common reason for a car pulling is the rear toe being off.
Cut springs are very inconsistent in thier behavior, and its possible that one of the rear ones settled differently when you were changing the tires, causing a siltightly different toe.
Old Jan 18, 2007 | 09:29 AM
janz3n's Avatar
Default Re: MY SEDAN PULLS RIGHT? DONT KNOW WHATS WRONG.... PLEASE HELP (fireant)
why are you yelling at me???!!!! get an alignment. take out the cut springs.. cut springs are the stupidest thing every.
Old Jan 18, 2007 | 09:32 AM
djphonics's Avatar
Default Re: MY SEDAN PULLS RIGHT? DONT KNOW WHATS WRONG.... PLEASE HELP (janz3n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ryan89crx &raquo;</TD></TR><TR><TD CLASS="quote">turn caps lock off</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by janz3n &raquo;</TD></TR><TR><TD CLASS="quote">...get an alignment. take out the cut springs.. cut springs are the stupidest thing ever. </TD></TR></TABLE>
Old Jan 18, 2007 | 11:26 AM
havok hybrid's Avatar
Default Re: MY SEDAN PULLS RIGHT? DONT KNOW WHATS WRONG.... PLEASE HELP (djphonics)
your springs are making your car pull... Get a new set . Try buying a set of coil overs ....or even better.. just a 2 inch drop spring would be better for you.
Old Jan 18, 2007 | 11:28 AM
Rex-Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LONGLIVETHEEF &raquo;</TD></TR><TR><TD CLASS="quote">......... I DID CUT THE SPRINGS I DIDNT KNOW IF THAT WOULD MEAN ANYTHING.....</TD></TR></TABLE>
There lies your problem , like before mentioned , when you jacked up the car the springs stretch then when you lower the car they may not settle the same.
Hell a pair of " budget " springs lick Progressive springs beats the hell out of cut springs. Not to mention that setup is hell on the other components of your car.
Old Jan 18, 2007 | 12:35 PM
betsy84's Avatar
are you crazy fat? cuz that would make ur car pull
Old Jan 18, 2007 | 12:58 PM
GTSR5SEJ's Avatar
correction:
Rear toe being out will not cause a pull. if the thrust line however is out it can cause a crooked steering wheen but not a pull.
Cross Caster is the biggest reason a car pulls
also cross camber can pull but not as bad as caster.
Toe doesn't cause pulling
Old Jan 18, 2007 | 04:01 PM
EJgsr's Avatar
Default Re: (betsy84)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by betsy84 &raquo;</TD></TR><TR><TD CLASS="quote">are you crazy fat? cuz that would make ur car pull </TD></TR></TABLE>
Old Jan 19, 2007 | 09:53 AM
MHSD's Avatar
Default Re: (USDMej1)
i know cutting your springs is bad but to be honest i really dont care my car is rusty and slow.... i just hate when im driving in the snow and i lose control because i took my hand off the wheel for two seconds... how much would a cheap set of springs cost??? is there any certain kind i should get??? its just a beater right now so im not going to puty a lot of money into it.. cheap is neat..
oh and bryan thnks for the thumbs up..... your the man... call me when you get a real car...
Old Jan 19, 2007 | 12:09 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (LONGLIVETHEEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LONGLIVETHEEF &raquo;</TD></TR><TR><TD CLASS="quote">i know cutting your springs is bad but to be honest i really dont care my car is rusty and slow.... </TD></TR></TABLE>
So why drop it in the first place?
Old Jan 19, 2007 | 12:12 PM
MHSD's Avatar
Default Re: (wiZCo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo &raquo;</TD></TR><TR><TD CLASS="quote">
So why drop it in the first place?</TD></TR></TABLE>
because i dont like cars that sit ten feet up in the air.. i just wanted to make it look better.
Old Jan 19, 2007 | 12:36 PM
89efDUSTY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by janz3n &raquo;</TD></TR><TR><TD CLASS="quote">why are you yelling at me???!!!! get an alignment. take out the cut springs.. cut springs are the stupidest thing every. </TD></TR></TABLE> holy crap...added to my sig...hahaha
Holy crap...what is wrong with some of these answers...this page is going to hell
Old Jan 19, 2007 | 02:05 PM
eur0's Avatar
Default Re: MY SEDAN PULLS RIGHT? DONT KNOW WHATS WRONG.... PLEASE HELP (89efDUSTY)
cutting springs is ghetto to the max, invest a little money into your car and your own safety and do it right...
Old Jan 19, 2007 | 03:40 PM
janz3n's Avatar
Default Re: MY SEDAN PULLS RIGHT? DONT KNOW WHATS WRONG.... PLEASE HELP (eur0)
wow.. i feel honored to be in someones sig. thanks. lol.. but anyways. even if your car is slow and rust you shouldnt put cut springs in your car.. id otn think a shop would bother doing an alignment unless you replaced them.. unless they dont care and just want your money. unless you want to hit a bump one day and loose control of your car and kill your self and maybe even someone els.. i dont really care if you die.. but id hate to see you kill someone els. and thanks for turning your caps lock on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LONGLIVETHEEF &raquo;</TD></TR><TR><TD CLASS="quote">oh and bryan thnks for the thumbs up..... your the man... call me when you get a real car...</TD></TR></TABLE>
a real car??? i didnt know people come on to honda tech because they just bought a model car. that comment was pretty stupid and it tells me you have a low IQ
Old Jan 20, 2007 | 06:43 PM
EJgsr's Avatar
a real car??? i didnt know people come on to honda tech because they just bought a model car. that comment was pretty stupid and it tells me you have a low IQ</TD></TR></TABLE>
hes my friend and he knows that my car is way better than his.
Old Jan 23, 2007 | 08:05 AM
MHSD's Avatar
Default Re: MY SEDAN PULLS RIGHT? DONT KNOW WHATS WRONG.... PLEASE HELP (USDMej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMej1 &raquo;</TD></TR><TR><TD CLASS="quote">
hes my friend and he knows that my car is way better than his. </TD></TR></TABLE>
brian you actually think that piece of cow **** with wheels that you drive is better then my car...... ALL DAY EVERY DAY TO YOU TAYLOR!!!!!!!!!!!!!!!!
92ehatch
23
Nov 4, 2005 01:48 PM
Solracer
22
Nov 3, 2004 02:47 PM
2 point 0
30
Apr 10, 2004 08:52 PM
TegLove
May 8, 2003 05:08 AM
LoooseGSR
Apr 16, 2003 12:55 PM
