how to remove e-brake cable on drum brakes???
Old May 15, 2002 | 05:21 PM
91civ's Avatar
Default how to remove e-brake cable on drum brakes???
i am doing a rear disk swap and need to switch e-brake cables. How do they come off the drum breaks? Got the disk brakes figured out...they were EASY! But the drums look a little bit harder.
Old May 15, 2002 | 07:22 PM
Giuseppe's Avatar
Default Re: how to remove e-brake cable on drum brakes??? (91civ)
you cant reuse your drum ebrake cables anyways...
grind those suckers off!
Old May 16, 2002 | 05:18 AM
Doodoo's Avatar
Theres a little pin at the end where the cable connects to the drum. Use pliers to bend it and remove. Voila!! simple.
Old May 16, 2002 | 05:36 AM
WuShu's Avatar
New User
Default Re: how to remove e-brake cable on drum brakes??? (Doodoo)
their called cotter pins i believe and you cant reuse em so get a new pack.
Old May 16, 2002 | 09:46 AM
91civ's Avatar
thanks guys but i think i'm just gonna go get some off a 90-93 integra, i think that will be better cause it never hurts to upgrade thanks for the help though
the_dxB16
Mar 8, 2009 08:36 AM
tekstyle
Dec 10, 2007 01:40 AM
frstbte14
May 3, 2007 12:05 PM
aeboync
Dec 30, 2006 10:16 AM
coupe_hybrid
May 20, 2006 09:31 AM
