motor mounts. 92-95 are they the same for a d-series and b-series?
Old Jan 17, 2007 | 11:38 PM
dem0nk1d's Avatar
Default motor mounts. 92-95 are they the same for a d-series and b-series?
i was looking online and i found a upgrade kit for a b-series motor mounts in a eg. it says they can be used on a d-series or b-series. So if this is true if you upgraded to a b-series in your eg you can swap mounts right on your old D-series motor, and bolt them onto the B-series motor.... WTF>>
Old Jan 17, 2007 | 11:40 PM
I Shot 50 Cent's Avatar
B series and D series mounts are different. That website is incorrect. You are correct.
Old Jan 17, 2007 | 11:54 PM
dem0nk1d's Avatar
Default Re: (I Shot 50 Cent)
I guess which mounts are then needed should i stay stock, or go after market mounts? For a b-series into a eg. Almost forgot don't the b-series axels have to use the outter 92-95 cv hubs?
Old Jan 18, 2007 | 12:20 AM
Luserkid's Avatar
Default Re: (dem0nk1d)
92-95 Civic and 94-00 integra MOUNTS are the same. Brackets are different. For 96-00 Civic im 95% sure the trans upper mount and the rear trans mount are the same, upper driver is not.
Both Torque mounts are not the same between Civic and Integra of all years.
Old Jan 18, 2007 | 01:42 AM
Richard...'s Avatar
Default Re: (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">92-95 Civic and 94-00 integra MOUNTS are the same. Brackets are different. For 96-00 Civic im 95% sure the trans upper mount and the rear trans mount are the same, upper driver is not.
Both Torque mounts are not the same between Civic and Integra of all years. </TD></TR></TABLE>
unless you converted with that bracket
Old Jan 18, 2007 | 01:58 AM
blk_eg4's Avatar
Default Re: motor mounts. 92-95 are they the same for a d-series and b-series? (dem0nk1d)
the driver and tranny mounts can fit from a d-b series but the rear bracket on a b series will have to be lengthen to fit the rear mount properly...
Old Jan 18, 2007 | 03:35 PM
dem0nk1d's Avatar
so your saying the mounts from my d-series out of my 95 civic hatch will bolt onto the driver side top mount, and tranny side of the integra long bloc. but the lower torques must be swap out and the rear bracket needs to be changed..
Old Jan 18, 2007 | 11:10 PM
blk_eg4's Avatar
all 3 mounts are cool...driver side and tranny side brackets will bolt up to the mounts except the rear bracket, you have to change it or lengthen it to bolt up to the rear mount
Old Jan 19, 2007 | 08:54 AM
Luserkid's Avatar
Default Re: (jdmETi)
I think this is what your looking for:
Old Jan 19, 2007 | 09:00 AM
White Ice's Avatar
That is good information. Even though I did not ask the question thank you for clearing that up.
Old Jan 19, 2007 | 09:41 AM
crispy93's Avatar
that just saved me from making a new post...thanks Luserkid
kiddcarbuff's Avatar
correctormudo! swap the rear t bracket to one from a 3g teg and you're set
Old Jan 19, 2007 | 09:49 AM
Harryflores's Avatar
Default Re: (kiddcarbuff)
Thanks Luserkid Good Info !!
Old Jan 20, 2007 | 03:46 PM
dem0nk1d's Avatar
but in thath picture it SAYS use the 3g driver side top mount.
Old Jan 20, 2007 | 03:47 PM
dem0nk1d's Avatar
just bought an ls, i am going to drop it in as soon as i get axels, and shift linkage. aslo i hear the 90-93 integara shift linkage will work fine.
Old Jan 20, 2007 | 05:59 PM
^^ it will!
Old Jan 20, 2007 | 06:55 PM
Luserkid's Avatar
It will but the intermediate shaft is a male/female so youll need a male/male axle for the driver side.
JordanDC5
Northeast (Sales)
Sep 23, 2011 11:28 AM
Pompiuses
Oct 18, 2007 11:50 AM
