brake problems..
Old Jan 17, 2007 | 05:48 PM
whitehf's Avatar
Default brake problems..
i have a 96 hatch with stock brakes...well after i changed my brakes its stop working properly.....sometimes when im rolling and i step on the brake it sinks all the way in and if i smash it all the way my driverside wheel locks....but if i pump it twice before im going to stop then it works fine....im thinking theres air in my brake hoses or its my master cylinder....i bleed all 2 front brakes after i changed my brakes...help plz....
Old Jan 17, 2007 | 05:52 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: brake problems.. (whitehf)
you may need to bleed them..or check your master
Old Jan 17, 2007 | 05:54 PM
egmatt93's Avatar
Default Re: brake problems.. (Throwdown)
bleed them. let us know if it works
Old Jan 17, 2007 | 09:32 PM
jdmmotorsports's Avatar
Default Re: brake problems.. (egmatt93)
Bleed the brakes and check the master cylinder. If you dont see the and leaks coming from the master cylinder you could in internal leak inside the master cylinder. Bleed all four wheels and start from the right rear.
Old Apr 11, 2007 | 06:31 PM
whitehf's Avatar
Default Re: brake problems.. (jdmmotorsports)
did all that...ran it for a day worked fine..then started acting up again...first pump the brakes kinda work but its really really deep in..second pump starts to feel normal...what can be the problem
Old Apr 11, 2007 | 07:09 PM
excivicboy96's Avatar
did you bleed all four or just two? check for leaks.
Old Apr 15, 2007 | 05:42 PM
whitehf's Avatar
Default Re: brake problems.. (excivicboy96)
bleed all four and there are no leaks
Old Apr 15, 2007 | 05:45 PM
BADHDRIVER's Avatar
what kind of brake pads did you buy..pls tell me you did not buy those $15.00 pads
Old Apr 15, 2007 | 10:30 PM
EGhatch87's Avatar
check your wheel brake cylinder in the rear drum(if there drums) if not then it your master cylinder
Old Apr 16, 2007 | 10:48 PM
whitehf's Avatar
Default Re: (210EGhatch)
im thinking its the master cylinder..but it still pumps...sometimes wen im driving and the pedal sinks in...it feels like only the driver side brakes are working because my car kinda shifts..
Old Apr 16, 2007 | 10:52 PM
sol2hatch's Avatar
Default Re: (whitehf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whitehf &raquo;</TD></TR><TR><TD CLASS="quote">im thinking its the master cylinder..but it still pumps...sometimes wen im driving and the pedal sinks in...it feels like only the driver side brakes are working because my car kinda shifts..</TD></TR></TABLE>
sounds hella dangerous, you should get that **** fixed before we have to read about your car crash.
DerekHollister
24
Sep 15, 2017 03:17 PM
charlee
Dec 17, 2006 04:01 PM
4play4dr
Nov 13, 2006 11:39 AM
ice11honda
Feb 24, 2005 12:56 PM
GReddy SI
Jul 17, 2003 09:36 PM
