queston on hondata s200
meaning switch between two different maps for hi/low boost? you can probably burn one map onto a chip and another on another chip then switch them out.
with neptune you can have two maps made and switch between them with the flip of a switch.
There is also a part called a two timer. And you use a chip with 512 memory, and burn the first map in the 1-256 memory and the other map on the higher part of the memory. You just have to edit the adress that the chip burner actually burns in the chip.
http://www.moates.net has the 2timer. That is the thing you can use to switch maps with.
But as far as internal, Neptune has dual map capability.
Also, if your tuner has the latest ROM Editor (version 4) you can set up the secondary maps to do that for you as well. You can set the parameters for that, and when they are meet, you will kick on to those maps. You can activate them through one of the 2 nitrous activation set points.
Jason
Jason
nytosc
Engine Management and Tuning
10
Aug 18, 2011 09:58 AM
