Turbo Parts HERE!!!LS/VTEC motor, Full Race IM w/ BBK TB, Comp twin disc clutch, Precision AR.70 tur
From: ...and then along comes the fcuking policia, PA
Fully built LS/VTEC (B18A1 & P72) by Justice Racing Engines
Darton sleeves
Solid deck
CP Pistons 85mm
Manley Rods
Block has been decked and align honed
Race port on head
Race valve guides
Full Ferrera valve train
Intake valves oversized 1/2 mm
Comp Cams turbo cams
Full Race cam gears
A1 Tech head and main studs
Moroso aluminum oil pan and pickup
Internally worked oil pump
Motor will be rebuilt and freshened up before sold.
$6000 or make me an offer...$7500 for everything listed here
*clutch NOT included in sale of motor*
Custom exhaust manifold, Tial wastegate, dumptube and custom downpipe
$600
*pic with turbo attatched*
Precision P-67 ball bearing turbo (AR.68 turbine side/ AR.70 compressor side) rated to 780hp *check their site for exact specs, it is the first P-67 listed with the 3" inlet/2" outlet*
$850
Full Race Intake manifold with BBK 70mm throttle body manifold drilled to fit both B16, ITR stud pattern or GSR stud pattern
$850
Comp clutch twin disk with @ 20 runs on it
SOLD
picture of clutch discs....plenty of gription left
The following pics are of each part of the clutch assembly with pics of both sides of each disc.
Thanks for looking
Modified by attentionwhore at 4:42 PM 1/21/2007
Modified by attentionwhore at 10:07 PM 1/23/2007
Modified by attentionwhore at 11:35 AM 1/24/2007
Modified by attentionwhore at 9:02 PM 1/24/2007
Modified by attentionwhore at 6:07 AM 1/27/2007
Darton sleeves
Solid deck
CP Pistons 85mm
Manley Rods
Race port on head
Race valve guides
Full Race cam gears
$600
$850
$850
SOLD
Thanks for looking
Thank-you my good man. So you know the quality....buy, buy, buy. The motor is actually going to Jim on Sat. to be completely rebuilt for the sale. Freshness FTW!
Yes I still have the turbo. The motor it was on was a LS/VTEC so the exhaust manifold will fit B16 or 18 and the intake manifold is drilled to fit either a B16/ITR head or a GSR head.
JdmDan
Jan 21, 2009 10:34 AM
simplsi
Mid-Atlantic (Sales)
12
Aug 24, 2008 11:09 PM
attentionwhore
Apr 13, 2007 01:50 PM
