wtf is my cars problem
so when all my sensors are pluged in like my tps and my iacv it will fluxuate in idle from like 1g to 2g's and when i unplug my tps sensor it will just idle at 1500 or around there but doesnt fluxuate...is my tps sensor bad?
Is your idle set to the right RPM? Make sure the idle is set to 825rpm+ -
with the screw. Also check ur resistance on the TPS as stated.
It should be .5 closed and .45 wide open I believe.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ericstambaugh07 »</TD></TR><TR><TD CLASS="quote">so just drain all my coolant? or what? </TD></TR></TABLE>
No, bleed it like he said.
Follow your lower radiator hose, it will conect to the thermostat housing by the back left corner of the cylinder head. You will see a little bolt with a hole in it, this is the bleeder nipple. Take off your radiator cap and unscrew the bleeder nipple, once you see a steady stream of coolant comming out your done.
i did it with the car running and with the radiator cap off..and it will come out of the radiator sometimes and when it rev's up the coolant will come out of the bleeder screw..but when its down toward 1000rpm's none will come out
Modified by ericstambaugh07 at 11:23 AM 1/18/2007
Guest
Posts: n/a
if your car is steady ilding high or low then you can adjust the idle on the throttle body. but first you need to go back and make sure that your not loosing coolant through the bleeder screw. if that doesnt work try what championshipwhite93si said.
the search button was my friend indeed...
im haveing the same problem so i will definatly try bleeding the system the way it was mentioned earlier... qick question tho, i have a Ls out of a 92 teggy, the bleeder screw is on the upper radiator hose just off the head... dose the same princaple apply...? thank you, Brian
