help! hydro conversion on my hf
Old Jan 17, 2007 | 04:53 PM
Sloshy's Avatar
Default help! hydro conversion on my hf
I'm having problem figuring out what axles to use, I have hydro gsr axles and hydro
halfshaft, my problem is that the knuckle's holes for the axles are to small, im a noob
at crx's so what im i suppose to do? thanks for the help guys
Old Jan 17, 2007 | 05:55 PM
Sloshy's Avatar
no one knows?
i just read that i need dx/si knuckles, but i want to now if i can use any other knuckles othere than those beacause they're hard to find
Old Jan 17, 2007 | 05:57 PM
Crx Jimmy's Avatar
Default Re: (hatch-E-vanish)
you need dx or si hubs!, or upgrade to some da spindles for some bigger brakes as well
Old Jan 17, 2007 | 06:23 PM
Sloshy's Avatar
so da spindles work too, is it plug and playor is there modification?
i also have a set of eg spindles would those work
Old Jan 18, 2007 | 07:09 AM
Sloshy's Avatar
bump!!!
will da spindles fit hx wheels before i go hunting for them?
Old Jan 18, 2007 | 11:30 AM
dephtone's Avatar
DA Spindles will work for your HF, and No Hx wheels will not work. My buddy has DA spindles knuckles etc on his sedan and he can't run anything lower than a 14" wheel because it will hit the caliper. So if you do DA knuckles etc you MUST run a 14" wheel.
Old Jan 18, 2007 | 02:09 PM
Super Chicken's Avatar
Default Re: (dephtone)
I thought HX wheels were 14" No?
VX are 13"
Old Jan 18, 2007 | 02:56 PM
Sloshy's Avatar
just found out how to run HX with da spindles from a fellow member http://www.performanceforum.co....html
90civicstdgold
May 17, 2009 08:36 PM
80 dolla crx hf
Jun 9, 2008 03:03 AM
mikesrex
12
Sep 18, 2006 06:25 PM
TABIAS
19
Feb 11, 2005 11:10 AM
1CiViC1
May 29, 2003 02:29 PM
