Help Changing a fuel pump
Old Jan 17, 2007 | 04:42 PM
nicko360's Avatar
* B A N N E D *
Default Help Changing a fuel pump!!!!!!!!!!
I am pretty sure I need a new fuel pump in my eg, is it still possible to start a car without a fuel pump, b/c mine starts, but then dies...
How hard is it to change a fuel pump, are there any lines that need to be blocked off?
Thanks
Old Jan 17, 2007 | 04:52 PM
nicko360's Avatar
* B A N N E D *
Default Re: Help Changing a fuel pump!!!!!!!!!! (nicko360)
bump for some help
Old Jan 17, 2007 | 05:10 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
you may want to look more into this instead of assuming its the fuel pump and wasting money
Old Jan 17, 2007 | 05:12 PM
nicko360's Avatar
* B A N N E D *
Default Re: Help Changing a fuel pump!!!!!!!!!! (Throwdown)
i've tried changing my fuel pressure regulator and fuel filter already,
the fuel pump sounds different when i turn the car on
Old Jan 17, 2007 | 05:14 PM
Throwdown's Avatar
like can't hear it? check the main relay...
nicko360's Avatar
* B A N N E D *
whats that?
Old Jan 17, 2007 | 05:15 PM
nicko360's Avatar
* B A N N E D *
i can hear the fuel pump turn on but it sounds different
the car starts but bogs out after a couple secs
Old Jan 17, 2007 | 05:17 PM
Throwdown's Avatar
... ok so does your can shut off completely? or only "bogs"
Old Jan 17, 2007 | 05:21 PM
nicko360's Avatar
* B A N N E D *
the car bogs then shuts off
the only way I can keep it alive is by tapping the gas, consistant pressure cuts it off
Old Jan 17, 2007 | 05:25 PM
Throwdown's Avatar
ok...well when it shuts off does it start RIGHT back up? or you have to wait ? this could be a few things i'm just tring to narrow them down
Old Jan 17, 2007 | 05:35 PM
nicko360's Avatar
* B A N N E D *
the next few times it doesn't start up, but then it will start up again after a few trys
Old Jan 17, 2007 | 05:39 PM
Throwdown's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Throwdown &raquo;</TD></TR><TR><TD CLASS="quote">ok...well when it shuts off does it start RIGHT back up? or you have to wait ? this could be a few things i'm just tring to narrow them down</TD></TR></TABLE> ok when it does this you should check for fuel and spark then ....go from there
Old Jan 17, 2007 | 05:58 PM
egmatt93's Avatar
take out back seats, you will see the cover take the screws out disconnect the wiring and pull it out. connect the new one, put it in, put screws back in and put ur seats back in
Old Jan 17, 2007 | 06:03 PM
wip_customs's Avatar
This is VERY easy to do as stated take out the rear seats and there you go.
Old Jan 17, 2007 | 06:04 PM
Throwdown's Avatar
Default Re: (wip_customs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Throwdown &raquo;</TD></TR><TR><TD CLASS="quote">you may want to look more into this instead of assuming its the fuel pump and wasting money</TD></TR></TABLE>
Old Jan 17, 2007 | 06:22 PM
Zeusfire69's Avatar
Default Re: (Throwdown)
Fuel pressure regulator? Check your fuel pressure..
4doorcivic9
Jun 11, 2008 06:31 AM
iNDyCRX
Apr 24, 2008 12:54 PM
92 white eg
Aug 4, 2007 03:12 PM
Cameron60
Jan 16, 2007 06:04 PM
mikefxu
Dec 1, 2003 02:22 AM
