Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
J35 Throttle Body Pinout
Old Jan 17, 2007 | 03:47 PM
burnout8488's Avatar
Default J35 Throttle Body Pinout
Need a pinout for a J35 drive-by-wire throttle body. If nobody can produce one, I have one question.
Is there a TPS wire?
Old Jan 18, 2007 | 02:55 AM
Ross 2.0's Avatar
In a Junkyard near you.
Is this for your vue? How much of a shock was that when you found out you had a Honda engine?
Old Jan 18, 2007 | 09:45 AM
Yes, I want to install a VAFC. The ECU that drives my motor only opens the throttle 75% in 1st gear, and disables VTEC in 1st gear. :/ I'm hoping I can turn VTEC back on with this, and maybe lower engagement to 4000rpm.
Oh, and I wouldn't have bought the car had it not had the honda under the hood :-)
Old Jan 18, 2007 | 09:47 AM
Ross 2.0's Avatar
ehh what kind of sorcery is that!
take a quick picture of the TB connector just to be sure it's the same part. and i'll get that breakdown for you
Old Jan 18, 2007 | 04:57 PM
Aghh, just found out today at the dealer that if VTEC is turned on not by way of the ECU, the ECU will freak out and throw a code... and possibly go into limp mode...
How do people install VAFCII's on OBDII motors?
boostcrx89
Jan 6, 2008 05:46 PM
honda305
Sep 3, 2006 04:48 PM
lilbill3554
Jan 28, 2004 07:39 PM
GSlowR
Jun 24, 2003 11:36 AM
hooptie157
Mar 4, 2002 10:38 AM
