Here we go again........
Old Jan 17, 2007 | 03:35 PM
turbovybez's Avatar
Default Here we go again........
Ok guys. Any and all help I can get will be greatly appreciated. I have searched and found nothing. I have asked some questions maybe they were the wrong ones. I have a 94 civic dx coupe complete with the punny d15b7. I aquired a d16y8 from a 99 civic ex sedan. I have since taken the head off of the y8 and swapped it onto my d15 block. There are a couple of things that dont seem to match up. Of course for one I know I have to splice the injector harnesses in to my wiring harness. I have connected my fuel return and feed lines. I have connected my map sensor. The only things that are confusing me are the iacv and i believe it is the pcv. If I am not mistaken the pcv on the 99 is electronic. If so how do I go about incorporating that into my vehicle. Also the iacv on my wiring harness is 2 wire and I believe the one on the 99 is a three wire. I would like to know if there is anything I need to add or delete in order to make it work. If anybody has gone through this before please help a fellow civic enthusiast out. Also if anyone knows anything I might need to know or something that I may have gotten mixed up or forgot please be kind and let me know. Thanks in advance.
-Turbovybez.........."Be it unto me"
Old Jan 17, 2007 | 03:43 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: Here we go again........ (turbovybez)
you have a auto y8 manifold or manual? ..
Old Jan 17, 2007 | 06:42 PM
turbovybez's Avatar
Default Re: Here we go again........ (Throwdown)
auto. does that make a difference. i didnt know that.
Old Jan 17, 2007 | 07:06 PM
Throwdown's Avatar
yes the iacv is on the TB .... not on the manifold
Old Jan 17, 2007 | 07:08 PM
turbovybez's Avatar
ok. soooooooo............ whats the difference.
Old Jan 17, 2007 | 07:13 PM
KtHaNxBai's Avatar
i think u need todo the conversion from 3 wires to 2.
Old Jan 17, 2007 | 07:14 PM
Throwdown's Avatar
https://honda-tech.com/zerothread?id=1083436 check this out it explains it and the air injector sys that you have to plug i just went through this lucky Bense had one already done
Old Jan 17, 2007 | 07:29 PM
turbovybez's Avatar
Thanks for the info. Do you have any pics of where these holes are that you plugged and tapped.
Old Jan 17, 2007 | 07:35 PM
Throwdown's Avatar
no ...but they are real small and they are on top and infront of where the injectors sit ...4 holes
Old Jan 17, 2007 | 07:39 PM
Throwdown's Avatar
https://honda-tech.com/zerothread?id=1750513 heres a better thread on the iacv thing and i'm making a picture for you about the air injector sys
Old Jan 17, 2007 | 07:42 PM
Throwdown's Avatar
Shadows_fire13
Apr 16, 2019 08:10 PM
Rafael Amador
Apr 11, 2019 11:36 AM
Josh1999Civic
May 18, 2018 03:54 AM
jplowman2005
Oct 3, 2008 06:20 PM
Cprace1
Sep 12, 2005 09:50 AM
