OEM JDM Type R header vs. Replica
Old Jan 17, 2007 | 01:43 PM
skata89's Avatar
Default OEM JDM Type R header vs. Replica
Ive looked around for something but can find that much and I was wondering if there are any differences between the two when there both made to the same specs. Bc I can pick up a OEM one for 200 or buy a brand new replica one for about the same. Also this will fit in my price range. Which one do you guys recommend to get?
Old Jan 17, 2007 | 01:52 PM
walker111's Avatar
Default Re: OEM JDM Type R header vs. Replica (skata89)
I recommend the OEM 4-1, some replicas have fitment issues..
Old Jan 17, 2007 | 01:54 PM
skata89's Avatar
Even as used? Also would you notice a differences between the two?
Old Jan 17, 2007 | 01:57 PM
OG undercover's Avatar
Default Re: (skata89)
OEM 4-1 and not a single problem
Old Jan 17, 2007 | 02:03 PM
skata89's Avatar
Well I decided to go OEM. Is there any stamps I should look for to make sure its real?
Old Jan 18, 2007 | 08:34 AM
QuickDxEk's Avatar
I would also recommend the OEM Jdm ITR header. Bad *** header!!
Old Jan 19, 2007 | 01:56 PM
skata89's Avatar
Well im going to go get this header tomorrow hopefully but i would like to know if there is a way to id it to make sure its real. Like a stamp or something.
Old Jan 25, 2007 | 05:19 PM
skata89's Avatar
bump need a way to id a oem jdm itr header.
Old Jan 26, 2007 | 05:19 AM
tartje's Avatar
the OEM will have plates welded on to allow a heatshield to be bolted onto it.
et voila:
Old Jan 26, 2007 | 05:55 AM
ebelp's Avatar
Default Re: (tartje)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tartje &raquo;</TD></TR><TR><TD CLASS="quote">the OEM will have plates welded on to allow a heatshield to be bolted onto it.
The replicas have the same brackets for the heat shield. The OEM JDM 4-1 header will have a stamp on it that looks something like this:
Old Jan 26, 2007 | 09:57 AM
jz98ctr's Avatar
if they're both about the same price...why wouldn't you get the JDM 4-1???
Old Jan 26, 2007 | 10:07 AM
itr1244's Avatar
Default Re: (jz98ctr)
i have an idea.
why dont you get a regular integra and turn that one into JDM type r replica.
so you can save some money to buy a real deal header
tartje's Avatar
Default Re: (ebelp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebelp &raquo;</TD></TR><TR><TD CLASS="quote">
The replicas have the same brackets for the heat shield</TD></TR></TABLE>
interesting, of all the replica's i've seen, they've never had heatshield brackets
Old Jan 26, 2007 | 10:22 AM
frstwhtgsr2000's Avatar
don't buy the replicas they are junk I was about to pick up a set from street imports/Yanaka and the workmanship was horriable, I showed the little runt there about the welds and agreed about the shitty work and would't lower the price usually they don't allow for pick ups so you never know what you will get
Old Jan 26, 2007 | 10:50 AM
white rocket's Avatar
Default Re: (frstwhtgsr2000)
I had a replica SS JDM 4-1 that I picked up for about $220 brand new from Street Imports a couple years ago. Fitiment was fine but the welds were complete ****. Only tack welded on the outside of the flange and the collector looked to be a bit of a hack job. It served it's purpose but I eventually upgraded to the Toda piece.
I'm not sure what the welds look like on the OEM piece since I've never seen one in person.
Old Jan 27, 2007 | 01:40 AM
NBPdEeCeE's Avatar
* B A N N E D *
Default Re: (white rocket)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebelp &raquo;</TD></TR><TR><TD CLASS="quote">The replicas have the same brackets for the heat shield. The OEM JDM 4-1 header will have a stamp on it that looks something like this:
What !? Damn. I bought what I believed to be JDM 4-1 ITR headers and it didn't have those stamps but the welds and stuff look great. Doesn't look like a hack job by any means.. And it has the brackets for the heat shield too
Old Jan 27, 2007 | 04:27 PM
DjMigs's Avatar
Default Re: (ViSioNxBoY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frstwhtgsr2000 &raquo;</TD></TR><TR><TD CLASS="quote">don't buy the replicas they are junk I was about to pick up a set from street imports/Yanaka and the workmanship was horriable, I showed the little runt there about the welds and agreed about the shitty work and would't lower the price usually they don't allow for pick ups so you never know what you will get</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white rocket &raquo;</TD></TR><TR><TD CLASS="quote">I had a replica SS JDM 4-1 that I picked up for about $220 brand new from Street Imports a couple years ago. Fitiment was fine but the welds were complete ****. Only tack welded on the outside of the flange and the collector looked to be a bit of a hack job. It served it's purpose but I eventually upgraded to the Toda piece.
I'm not sure what the welds look like on the OEM piece since I've never seen one in person.</TD></TR></TABLE>
damm i thought i struck gold when i found there website, was about to pick one up but at the last min i need ends for some bills and was gonna order some time soon but now that you fellas gave the heads up, **** im very thankful ... Cheers...whats funny is i should know better....dont support cheap product ...
Old Jan 28, 2007 | 03:44 PM
1sikhatch's Avatar
Default Re: (DjMigs)
are the size of the primaries the same or one of them is bigger?
Old Jan 28, 2007 | 05:57 PM
92TypeR's Avatar
FSAE
Default Re: (1sikhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1sikhatch &raquo;</TD></TR><TR><TD CLASS="quote">are the size of the primaries the same or one of them is bigger?</TD></TR></TABLE>
The DC has larger primaries and (IMHO) a better merge at the collector.
However, the OEM has the advantage of running heat sheilding, which makes the engine bay look stockish if that is your goal.
EviLLLLSiNz
Feb 25, 2009 09:29 PM
G_seven
Acura TSX
Mar 20, 2008 06:52 AM
dc2doi
Dec 9, 2006 04:27 PM
