okay this is weird? timing on B16A
take a look at those pics and let me know if thats normal the marks on the sides line up but the UP arrow on the intake cam gear is no really at the top straight up?
and how does this B16a Block look?
that motor^^ opened it up the day i got it from HMO
Modified by -HONDA- at 2:17 PM 1/17/2007
Modified by -HONDA- at 2:43 PM 1/17/2007
Modified by -HONDA- at 2:51 PM 1/17/2007
are they off either? they both line up on the sides ant see on the pic because it wont load all the way! but yeah the top aroows
Does it look fine or not?
the cam on the left is DUH the exhaust and the one on the right is INTake.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">The intake cam off if thats what your asking. </TD></TR></TABLE>
but if i try too put the intake cam with the arrow pointing up then the lines on the sides wont match up? someone help me please. the lines on the sides that line up like this - - they wont match up if i move it? right now they match up?
intake cam 1 tooth off , check your tensioner has the head been butchered , i mean shaved?get a straight edge and line up all 4 marks across the cam gears with the top surface of the head
when you put the tb on you should use a round phillips screwdriver or a punch to hold the cams in place at tdc, there are holes in the cam caps and in the cams that will line up at tdc for #1 cylinder. This helps to hold the cams in place because the valve springs will want to push the cams off tdc.
thats funny, I distinctly remember using them when repairing a poorly put together LS/VTEC motor which was made of a 99 B16 Si head and a 93 LS B18A block.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondacivic90ed »</TD></TR><TR><TD CLASS="quote">thats funny, I distinctly remember using them when repairing a poorly put together LS/VTEC motor which was made of a 99 B16 Si head and a 93 LS B18A block. </TD></TR></TABLE>
nope.. ls head only
nope.. ls head only
