ATP Turbo Restrictor Install
Old Jan 17, 2007 | 12:07 PM
McLude2nR's Avatar
Default ATP Turbo Restrictor Install
Just got my restrictor from atpturbo.com
http://www.atpturbo.com/Mercha...e=BCS
Kindof a noob. How do I install this? Do I have to cut the feedline or does it just fit between the feedline and the turbo oil inlet?
Old Jan 17, 2007 | 12:18 PM
notoriousB's Avatar
Default Re: ATP Turbo Restrictor Install (McLude2nR)
it goes between the turbo and the oil line fitting currently installed in the turbo.
Old Jan 17, 2007 | 12:49 PM
McLude2nR's Avatar
Default Re: ATP Turbo Restrictor Install (notoriousB)
Yeah, that's what I thought but it doesn't fit
Here's what I got:
The fitting that is going into the turbo is male to male.
The fitting on the oil feedline is female.
The fitting that I got from ATP Turbo is female to male, and the female side does not fit over the male side of the fitting on the turbo.
How the hell do I restrict the flow? Or is that fitting on the turbo going to restrict it sufficiently? Right now I'm at 90psi at WOT. and 20-30 at hot idle.
Old Jan 17, 2007 | 12:53 PM
komat's Avatar
take that fitting off the turbo
put the restrictor onto the turbo
put the silver fitting on the restrictor
Old Jan 17, 2007 | 01:02 PM
blackeg's Avatar
Default Re: ATP Turbo Restrictor Install (komat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat &raquo;</TD></TR><TR><TD CLASS="quote">take that fitting off the turbo
put the silver fitting on the restrictor</TD></TR></TABLE>
yep.
BE CAREFUL WHEN TIGHTENING THE RESTRICTOR IN THE TURBO!!!
i broke one of them when i tried to take it out. maybe put some teflon on there and tighten it hand tight. if its leaking its easy to see and you can tighten it a lil more, just dont go crazy the first time, trust me i happend to me
Old Jan 17, 2007 | 02:03 PM
McLude2nR's Avatar
I am teh idiota. Got it on there with some teflon around the restrictor going into the turbo. Not too tight, and not leaking. Thanks bros!
Old Jan 17, 2007 | 09:39 PM
peter.blais's Avatar
Default Re: ATP Turbo Restrictor Install (blackeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">
yep.
i broke one of them when i tried to take it out. maybe put some teflon on there and tighten it hand tight. if its leaking its easy to see and you can tighten it a lil more, just dont go crazy the first time, trust me i happend to me </TD></TR></TABLE>
Steel ones:
http://cgi.ebay.com/ebaymotors...48508
Old Jan 17, 2007 | 09:53 PM
ABK's Avatar
ABK
Default Re: ATP Turbo Restrictor Install (peter.blais)
do they really help with oil seals?
Old Jan 17, 2007 | 10:23 PM
Sprockets's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by peter.blais &raquo;</TD></TR><TR><TD CLASS="quote">Steel ones:
Good find, but you can get stainless steel restrictors from McMaster for about the same price.
Old Jan 18, 2007 | 06:00 AM
McLude2nR's Avatar
Default Re: ATP Turbo Restrictor Install (ABK)
There is some division on the boards, but I was advised by my Tuner (tuned1) and others that I should really get one considering the high oil pressures my engine puts out (80 PSi cold start and while cruising, 90PSi @WOT).
Old Jan 18, 2007 | 06:36 AM
Diyracing2's Avatar
would a stock turbo have a restrictor built in. Say your using a 14b turbo off a mitsu....
Just cause the motor produces 90psi doesnt mean the turbo sees 90psi right. whats a good way to test what the turbo is actually seeing?
Old Jan 18, 2007 | 07:25 AM
hionvtecxda6's Avatar
Default Re: ATP Turbo Restrictor Install (Diyracing2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Diyracing2 &raquo;</TD></TR><TR><TD CLASS="quote">would a stock turbo have a restrictor built in. Say your using a 14b turbo off a mitsu....
Just cause the motor produces 90psi doesnt mean the turbo sees 90psi right. whats a good way to test what the turbo is actually seeing?</TD></TR></TABLE>
i'm also wondering the same thing. another thing people tell me that since i run a -3 feedline, i don't need a restrictor. Is that true? The line i have running to my oil pressure sensor is also a -3, and both lines run from my sandwich plate, so both lines should be getting the same pressure right?
Old Jan 18, 2007 | 10:57 AM
McLude2nR's Avatar
The only turbos with built in restrictors that I have personally seen are some of the newer ball bearing series turbos (GT35R and so on). I'm not certain about the mitsu turbo.
My tuner advised that the pressure of the oil going into the turbo would not be significantly lower than what you are seeing on the guage. He said that if you really wanted to know, you could install the restrictor where the feedline attaches to the block, and install a small pressure guage right where the feedline enters the turbo.
Old Jan 18, 2007 | 01:25 PM
sleeprhatch's Avatar
Steel ones:
</TD></TR></TABLE> the quality looks like sht. I wouln't buy that thing.
roycivic92
Dec 15, 2007 06:58 PM
sanitarium
Jul 17, 2005 04:27 PM
kj98r
May 16, 2004 03:16 PM
el nano1983
Aug 21, 2003 12:31 PM
wantgoback
Apr 1, 2002 05:07 PM
