crx idle and check engine light problem
Hey i just bought another p28 because the last one was running rich, it had an ITR chip. Well the problems with the p28 i just bought are that it has an idle problem where it likes to keep itself at about 1.5 thousand rpm and there's a check engine light. I tried fixing by copying the precedures on this site https://honda-tech.com/zerothread?id=480385 , but my car is still having problems. any solutions?
Last time i got my d16z6 wired up in my crx, the mechanic used his p28 and it didn't have any problems, Is it a faulty ECU?
Any advise would be helpful thanks everybody
okay i just did a code check to see what going on its a code 9 which is the cylinder position sensor. how come this happened after changing ecu?
is the sensor hooked up to the ECU right? Could just be a bad sensor. You could test the sensor which is in the Dizzy I believe and that would tell you if it's the sensor or the ECU.
And did you have the problem and then put in the mechanic's ECU and it went away?
Gavin G
20
Aug 2, 2014 05:25 AM
