is the automatic cruise control unit different from a manual one??
I dont see why they would be??
I put an automatic cruise control gas pedal control on my manual pedal set because an automatic cruise pedal set was all I could find in the junkyard.
the cruise control unit I have is from a manual car (if I remember correctly)
even though I think I pulled everything from the same car in the yard (been in a box for over a year now).
anyway, when I put the cruise control throttle cable through the firewall to attach it to the pedal, it ends up pulling the pedal up like a quarter of the way.
do I need to adjust the main throttle cable out some to relieve the tension or are there two different length cruise control boxes for civics??
It's a 93 hatch and I have the cruise box bolted into the stock location. this has me puzzled.
Or is there a way to adjust the cable on the cruise unit??
nevermind, they are the same apparently. I just had to bend my gas pedal bracket a little and loosen the adjustment point on the cruise servo and the throttle cable.
then I just adjusted it all.
stokeswill
Mar 1, 2013 12:03 PM
Dropped90Integra
Jan 15, 2005 12:09 PM
