need help looking for some door speakers!
Old Jan 17, 2007 | 12:18 AM
raylude's Avatar
From: united states of mexico and yes ladies i am, available
Default need help looking for some door speakers!
i have a 99 prelude and both of my door speakers are blown they have blown before but i fixed them with silicone but now theres nothing left to glue
i like the factory system just fine so i was wondering where i can find some new speakers as close to stock as possible?
Old Jan 17, 2007 | 05:20 AM
perseverance's Avatar
get some 50dollar pioneer speakers. make sure they're 6.5". they're better than factory replacement but not too out of ur budget. you will need to either splice into the harness or buy a speaker harness adapter to install them. also u may need to possibly drill new speaker holes.
Old Jan 17, 2007 | 07:43 AM
fcm's Avatar
fcm
Old Fart
Default Re: need help looking for some door speakers! (raylude)
There are more then a few speakers out there that will do the job, and will be an easy install, especially with speaker harness adapters, You will need to find a standard 6.5" speaker, [not to be confused with the newer over-sized 6.5" speakers, a standard 6.5" speaker uses a 5" mounting hole, and you need one wit a mounting depth of 2" or less.
Both Pioneer and Infinity have one.
The Infinity REF6012SI come with an adapter ring so you can mount it using stock holes... http://www.infinitysystems.com/carau...er=REF&Cat=MEL
The Pioneer has a 6.5" "G" series speaker that will fit, there are a few others, many more that are deeper then 2", cutting the back out of the speaker housing can get you 1/2" - 1" of extra depth, and/or a depth reducing ring can be used for up to another inch. 94
Old Jan 17, 2007 | 08:37 AM
RICO_'s Avatar
NO MERCY!
Default Re: need help looking for some door speakers! (fcm)
You can get a good pair of Eclipse speakers which are good quality for the price and are also fairly shallow.
Old Jan 17, 2007 | 10:26 AM
raylude's Avatar
cool thanks guys
another question i have is while i went looking for those types of speakers i see 2way or 3way or 4way what does that mean?
also how many watts should i be lookin for?
Old Jan 17, 2007 | 10:41 AM
2way=midrange and tweet. 3way= midrange and 2 tweeters... etc. if you're looking for factory replacements then go with a 2way cause i'm almost sure u have factory tweets. then your highs will be nuts unless u disconnect them.
Old Jan 17, 2007 | 02:12 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Before you buy your speakers what are you using to power them? Stock headunit or aftermarket?
Old Jan 17, 2007 | 07:16 PM
fcm's Avatar
fcm
Old Fart
Default Re: need help looking for some door speakers! (wrx-killer-Sti eater)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrx-killer-Sti eater &raquo;</TD></TR><TR><TD CLASS="quote">Before you buy your speakers what are you using to power them? Stock headunit or aftermarket?</TD></TR></TABLE> OK, your not even looking anymore... "i like the factory system just fine".
I also would stick with 2ways, I ran two sets of Eclipse 6.5" 2ways for about 6 mo. off the stock HU and Alpine changer, then replaced the HU with an Alpine CDA-7893, still have the 7893 and the Eclipse 2ways, although the speakers have since been custom installed.
Unfortunately Eclipse no longer has a 2way coax, they have the SE8365, a 6.5" 3way... http://www.eclipse-web.com/integrated/se8365.html still a very good speaker, just a little bright for me, it is however almost a plug and play install, 5" mounting hole and under 2" in depth, the mounting holes will even line up with the ones in the stock plastic speaker housings.
As for wattage, no more the 50W continuous and you what to look at speaker sensitivity, anything over 89dB is good. 94
Old Jan 17, 2007 | 08:43 PM
EBP_SI's Avatar
Default Re: (perseverance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by perseverance &raquo;</TD></TR><TR><TD CLASS="quote">2way=midrange and tweet. 3way= midrange and 2 tweeters... etc. if you're looking for factory replacements then go with a 2way cause i'm almost sure u have factory tweets. then your highs will be nuts unless u disconnect them.</TD></TR></TABLE>
go with a 2way regardless. dont buy into the hype of more is better when it comes to the number of speakers. its actually almost the complete opposite.
or
your best bet is to find someone whos upgraded their door speakers and still has their originals laying around. try posting a WTB on any local forums. if you're happy with stock sound then the best thing to do is replace with stock. not many speakers are going to sound like them. (most will have much better response)
Old Jan 20, 2007 | 03:31 PM
raylude's Avatar
Default Re:
oops that right i forgot the stock cd player stoped working and i put in a panisonic cd player that says 50wX4 thats the only thing that i have changed everything else is stock
and i went to a local car audio shop and they recommended a couple
pioneer TS-G1641R 6 1/2'' 2 way coaxial speakers
infinity INF6012SI shallow mount 6 1/2" speakers 50 watts RMS power
thanks again for the help guys
Old Jan 21, 2007 | 12:26 PM
hobodo5's Avatar
i have my stock 99 prelude speakers if you want to buy them!!!
N1663R5
Audio / Security / Video
Aug 11, 2010 03:15 PM
Nuke209
Oct 11, 2007 02:33 PM
Civic_808
21
Jan 28, 2005 07:54 AM
SPARTUS
Dec 20, 2004 03:46 AM
ALF
Apr 15, 2003 03:52 PM
