How to install component speakers?
Old Oct 6, 2007 | 08:54 AM
Nuke209's Avatar
Default How to install component speakers?
My friend has a 2000 civic ex and wants to upgrade his speakers
So he has the amp wired up, all that is needed are the speaker wires
I was told to run the wires through the harness in the door jam
Problem is, getting to that harness
Are there any instructions or tips on how to do it? It seems a bit complicated (I'm a noob at audio installation)
Old Oct 6, 2007 | 09:15 AM
suspendedHatch's Avatar
Default Re: How to install component speakers? (Nuke209)
You could put the components in the door and use the oem speaker wires as the component inputs.
Old Oct 6, 2007 | 03:34 PM
fcm's Avatar
fcm
Old Fart
See if this helps... http://www.preludezone.com/printthread.php?t=500
Here is a pretty good one... http://www.the12volt.com/insta...~PN~1 94
Old Oct 9, 2007 | 03:11 PM
NVturbo's Avatar
O.G. triple O.G.
Unless he is planning on putting in a competition stereo system, there is no NEED to rewire the new speakers. Just use the factory wires.
Old Oct 10, 2007 | 07:34 AM
slowSOHCvtec's Avatar
Default Re: How to install component speakers? (NVturbo)
if you are looking to mount the crossovers inside your car vs in the door then rewiring thru the molex is the way to go. I want to do this for my car eventually.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NVturbo &raquo;</TD></TR><TR><TD CLASS="quote">Unless he is planning on putting in a competition stereo system, there is no NEED to rewire the new speakers. Just use the factory wires.</TD></TR></TABLE>
How else would you get speaker wire running from an amplifier to the input of the crossover for the components? Especially if the crossover is mounted inside the door. If you wire them this way, you can put the crossover inside your car and run the output wires of the crossover thru the molex, saving your crossover from some possible water damage
Old Oct 11, 2007 | 02:33 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: How to install component speakers? (slowSOHCvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowSOHCvtec &raquo;</TD></TR><TR><TD CLASS="quote">if you are looking to mount the crossovers inside your car vs in the door then rewiring thru the molex is the way to go. I want to do this for my car eventually.
How else would you get speaker wire running from an amplifier to the input of the crossover for the components? Especially if the crossover is mounted inside the door. If you wire them this way, you can put the crossover inside your car and run the output wires of the crossover thru the molex, saving your crossover from some possible water damage </TD></TR></TABLE>That is simple to do. At the deck, run your speaker wires towards the amplifier instead of wiring it to the deck. Now, that wasn't hard...was it?? I have installed numerous crossovers mounted on the door and there is no visible sign of water damage. Just don't leave it danglinig at the bottom of the door.
Gsrsi
Audio / Security / Video
11
Dec 5, 2012 07:09 PM
Andy_EJ8
Feb 8, 2011 12:02 PM
VTEC_PRODUCTION
Jul 14, 2007 11:43 PM
Bobaroo
Jul 1, 2007 09:32 AM
88crxfanatic
Oct 23, 2002 10:25 AM
