do you think this is a good setup...
Old Jan 16, 2007 | 11:18 PM
black_ek's Avatar
Default do you think this is a good setup...
i just want to know if my seup is good and is worth the money....i've spent almost 1g on the work on the motor....i took it to the track once and it was really weak...there was alot of problems and v-tec wasnt working.. i ran a 15.7 with bad tires in my EM1 2000 SI with nothing out...what i have....i want your guys advice if the setup is okay and my run was okay...
b18c1 block 81.50mm
new oversize p73 piston
stock reconditioned rods
micropolish stock crank
all new bearings
resurfaced block
b16a2 head
AEM cam gears
DC 4-1 header
2 1/2 GREDDY piping w/ SP2
b16 tranny
new OEM clutch
stock flywheel
stock ECU and fuel system ( had a chipped p28, but was sold because plan on getting a hondata s200 w/p28 for $250 )
just bought a type-r manifold w/out TB for $100
just traded my intake for a 68mm TB made by BBK
plan on getting some crower retainers and type-r valve springs for $160
im getting some toda B-SPEC $400
and ACT 6 puck clutch w/ flywheel
what you guys think ?
Old Jan 17, 2007 | 02:02 AM
Richard...'s Avatar
Default Re: do you think this is a good setup... (black_ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black_ek &raquo;</TD></TR><TR><TD CLASS="quote">i just want to know if my seup is good and is worth the money....i've spent almost 1g on the work on the motor....i took it to the track once and it was really weak...there was alot of problems and v-tec wasnt working.. i ran a 15.7 with bad tires in my EM1 2000 SI with nothing out...what i have....i want your guys advice if the setup is okay and my run was okay...
b18c1 block 81.50mm
all new bearings
resurfaced block
b16a2 head
AEM cam gears
DC 4-1 header
b16 tranny
new OEM clutch
stock flywheel
i am not trying to hate or flame you but i see this all the time and at the end of the day you have to ask your self are YOU happy with your setup?
personally i would ask anything you feel i could improve upon with this setup then again personally for me to give any advice i would need to know your goals for this engine and some numbers that your putting down right now
other then that it seems your on the right track for making power get it on the dyno tune it see were your at with this build!
and what LB flywheel you going to go with?
Old Jan 17, 2007 | 03:23 AM
gibsanez's Avatar
Default Re: do you think this is a good setup... (richard7968)
Camz? You could definatly find a better header. Stock ECU? That'll ding you in the horsepower department.
Old Jan 17, 2007 | 07:01 AM
b19coupe's Avatar
If the motor is mechanically sound and well put together it has potential. Get the Hondata and get it tuned.
Old Jan 17, 2007 | 08:09 AM
goforbroke's Avatar
MEAT PATTY
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black_ek &raquo;</TD></TR><TR><TD CLASS="quote">i took it to the track once and it was really weak...there was alot of problems and v-tec wasnt working.. i ran a 15.7 with bad tires in my EM1 2000 SI with nothing out
I think you need to stop beating on the motor and work out the problems and it also might help you if you figure out why vtec isn't working.......
Truthfully who who cares about the setup if motor isn't running correctly.
Old Jan 17, 2007 | 09:47 AM
Hardt's Avatar
Default Re: do you think this is a good setup... (goforbroke)
Why do so many people feel the need to pu up advise threads? If you really need advise regarding which parts to use or what direction to go with your build you probably shouldnt be building anything in the first place.
Threads like these clutter this forum, read, do, try, fail, succeed...... Knowledge is the most important thing you need when building anything. Thats what a lot of the guys who put these type of threads up lack and expect those who have done the research, done the homework to just hand over their knowledge????
jksmith
27
Dec 20, 2008 08:32 PM
4ev-Rnoob
17
Oct 6, 2008 04:00 PM
hitvtecgetloud09
90
Sep 6, 2005 04:22 AM
4nspeed
May 7, 2003 02:00 PM
90da4dr
Mar 27, 2003 07:56 PM
