Pistons...?
Old Jan 16, 2007 | 09:39 PM
Htounndea's Avatar
Default Pistons...?
Quick question for everybody out, im building my motor and just wanted to know what people suggest on what kind of pistons i should use, im doing a Ls Vtec set-up, im doing a GSR head with a B20z block and GSR tranny......
Old Jan 16, 2007 | 09:46 PM
bambam's Avatar
Default Re: Pistons...? (Htounndea)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Htounndea &raquo;</TD></TR><TR><TD CLASS="quote">Quick question for everybody out, im building my motor and just wanted to know what people suggest on what kind of pistons i should use, im doing a Ls Vtec set-up, im doing a GSR head with a B20z block and GSR tranny......</TD></TR></TABLE>
Well, first decide how often this car is going to be driven. Daily driver? Track only? Weekend cruiser?
Will you have the ability to tune? What kind of fuel will you be using? Stock sleeves?
Old Jan 16, 2007 | 10:06 PM
Hardt's Avatar
Default Re: Pistons...? (bambam)
Lluminum pistons are your best bet.
Although, when i called Toda/AKH Trading to find out what they recomended for piston to wall clearance with toda pistons, and they didnt know, i asked them what the exact alloy base of the forgings toda uses was (RR58, 2618, 4032, Mahle 124, etc) to get an idea of where piston to wall clearance should be (taking thermal expansion of each alloy type in mind), they went on to say "I think they are made of 4340 chromoly steel"
Old Jan 17, 2007 | 06:35 PM
Htounndea's Avatar
daily driven, stock sleeves, want high rev... im building my valvetrain with over sized everything maybe Type R cams and cam gears or skunk 2 stage 2...
Old Jan 17, 2007 | 09:27 PM
bambam's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bambam &raquo;</TD></TR><TR><TD CLASS="quote">Well, first decide how often this car is going to be driven. Daily driver? Track only? Weekend cruiser?
Will you have the ability to tune? What kind of fuel will you be using? Stock sleeves?</TD></TR></TABLE>
Good. Now answer the rest of the questions and we may be able to help you further.
Old Jan 17, 2007 | 10:51 PM
ExospeedAMcrx's Avatar
Default Re: Pistons...? (Hardt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hardt &raquo;</TD></TR><TR><TD CLASS="quote"> "I think they are made of 4340 chromoly steel"
Theyre great representatives for the brand.
Old Jan 17, 2007 | 11:12 PM
92TypeR's Avatar
FSAE
Default Re: Pistons...? (exospeedAMcrx)
Had great success with CP's.
Low thermal expansion = no "piston slap" and tighter piston/wall clearances.
Old Jan 18, 2007 | 04:16 PM
Htounndea's Avatar
Default Re: Pistons...? (92TypeR)
What does CP stand for...?
Old Jan 18, 2007 | 04:21 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Htounndea &raquo;</TD></TR><TR><TD CLASS="quote">What does CP stand for...?</TD></TR></TABLE>
Compton.... oh wait thats CPT
Old Jan 18, 2007 | 04:33 PM
Htounndea's Avatar
what do those usually run for, and power wise?
Old Jan 18, 2007 | 05:44 PM
doood's Avatar
been there done that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Htounndea &raquo;</TD></TR><TR><TD CLASS="quote">what do those usually run for, and power wise?</TD></TR></TABLE>
seriously how about you put some of your own effort into answering your own questions
Old Jan 18, 2007 | 05:54 PM
If you're going to Eagle Rock Meet, hit me up. I'll be there today... I can answer some of your questions.
Old Jan 18, 2007 | 06:33 PM
92TypeR's Avatar
FSAE
CP stands for CP
Old Jan 18, 2007 | 06:35 PM
RedEj8's Avatar
You need gold plated pistons, with diamonds in the valve reliefs.i believe paul wall makes some..bling bling
Modified by RedEj8 at 10:52 PM 1/18/2007
Old Jan 18, 2007 | 06:41 PM
smileycvc's Avatar
Default Re: Pistons...? (RedEj8)
roll with some wiseco's thats what i use and a bunch of the guys I know with all motor builds.
Old Jan 18, 2007 | 07:41 PM
Htounndea's Avatar
If your not helping then dont reply and waste my time...
For those of you working with me thnx...
Old Jan 18, 2007 | 08:15 PM
..........'s Avatar
Default Re: (Htounndea)
K567M84 wiseco shelf stock, 2cc dome, 11.3-12cr with gsr head, thats wat i would go
Old Jan 18, 2007 | 10:16 PM
RedEj8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Htounndea &raquo;</TD></TR><TR><TD CLASS="quote">If your not helping then dont reply and waste my time...
For those of you working with me thnx...</TD></TR></TABLE>
If you dont want to waste your time and all of ours..Then how about you use the damn search button...You will learn a **** ton...Every aftermarket forged piston will do the same damn thing..Its just up to YOU as to which one you would like to use..Its not our decision to make for your motor. Of course, if you want to paypal me 100 bucks i will tell you which pistons i would use in your motor...Good day sir
Old Jan 18, 2007 | 10:23 PM
IceySC's Avatar
Modified by IceySC at 3:17 AM 1/19/2007
Old Jan 18, 2007 | 10:33 PM
Htounndea's Avatar
Whats the difference between a 1.8L piston and a 2.0L piston, because im using a B20 block..?
IceySC's Avatar
i have a set of wisco 12.1 piston i'll be selling very soon they cam out of my gsr. i went turbo.
Old Jan 18, 2007 | 10:41 PM
vtecsi00's Avatar
Default Re: (IceySC)
i am using custom built cp pistons and seem to doing very well
Old Jan 18, 2007 | 11:10 PM
bambam's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Htounndea &raquo;</TD></TR><TR><TD CLASS="quote">Whats the difference between a 1.8L piston and a 2.0L piston, because im using a B20 block..?</TD></TR></TABLE>
b16/b17/b18 block = 81mm bore
b20 block = 84mm bore
Seriously man. These are the most basic things about hondas. If you don't even know the bore of your motor, please don't go wrenchin on it.
Old Jan 18, 2007 | 11:42 PM
slofu's Avatar
the best are found here: https://honda-tech.com/zerosearch
Old Jan 24, 2007 | 06:59 PM
Htounndea's Avatar
so i can use a 82mm bore as appose to 84mm what my block is, if i were to use different sleeves, or i can only use 84mm and up..?
