Occasional oil light... Weird symptoms- HELP!!
Old Jan 16, 2007 | 09:38 PM
Blaze45's Avatar
Brrraaaap!
Default Occasional oil light... Weird symptoms- HELP!!
know that WHEN it does come on, the car is getting 5psi or less... The car had been leaking oil from the last time I changed the oil and so I got under the car and took a look, the filter was leaking so I got a new filter and its not leaking anymore. However, it has had a small leak which I pinpointed to be the cam seal. I replaced it this saturday. No problems. Car ran fine for 2 days. Last night when my dad was on the way to work, the oil light came on. He was at the top of a hill so he shut it off and coasted to work. This morning he started it up and drove it home without an issue. Tonight we were picking up another car and the light came on again. I popped the hood and took the oil cap off and looked in with a flashlight and could see oil flinging around like it was getting plenty of pressure. As soon as he let off the gas and the RPMs dropped, the oil light would come back on. He kept the RPMs above 1000 on the way to work tonight and the light didnt come on at all. After work tommorow Ill be picking up a gauge and checking the pressure. I didnt drop anything to my knowlege into the oil passages when I did the cam seal change and the oil level is perfect. Im leaning towards a possibly bad oil pump? Can the oil pressure senders go bad? The car has 182k on it. Do the F series motors have weaker pumps then some other Honda engines?
Any help would be great. Tia.
Blaze
Old Jan 17, 2007 | 02:38 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Occasional oil light... Weird symptoms- HELP!! (Blaze45)
Anyone?
Old Jan 17, 2007 | 05:54 PM
96Spec Ek's Avatar
Yes the oil pressure switch probably has a build up of sludge in it. I would just replace it they're cheap enough, but if your broke just clean it with some brake cleaner and reinstall it.
Old Jan 17, 2007 | 07:50 PM
PrettyLude's Avatar
man the first thing i would do is hook up the gauge, and you'll know for sure, probably the pickup screen is clogged, but you might be lucky with just a bad oil pressure switch
Old Jan 18, 2007 | 02:14 PM
Blaze45's Avatar
Brrraaaap!
Default Re: (PrettyLude)
Replaced the sensor, no more oil light.
hatmanafro
Jun 28, 2011 08:43 PM
raverx3m
Dec 6, 2010 06:06 PM
EG_Warped
Dec 26, 2007 06:43 PM
Blaze45
Jan 17, 2007 03:34 PM
ludeman92
Nov 10, 2005 11:02 AM
