help!
Old May 15, 2002 | 02:28 PM
endob16a's Avatar
Default help!
i own a 89 si hatchback, and there is a whining/howling noise coming from the back end of my car when i drive. anyone know what it is, or can be? my dad thought it was a wheel bearing, but i was wondering if anyone knows. thanks.
Old May 15, 2002 | 02:32 PM
poison's Avatar
Default Re: help! (endob16a)
where specifically....is it coming from exhaust area, or wheels, or fuel pump area??? where where
no such thing as wheel bearing in the rear...at least from what YOU said, only bearings are in the front
Old May 15, 2002 | 03:06 PM
endob16a's Avatar
Default Re: help! (poison)
i believe it is coming from the tire/wheel area. it only makes the noise when i am actually driving/rolling in my car.
Old May 15, 2002 | 03:07 PM
poison's Avatar
probably rear brakes, im not positive, do u have discs or drums?
i think 89 si came with drums, could be wrong though.
how loud is it and what kind of noise??
Old May 15, 2002 | 04:29 PM
endob16a's Avatar
i have the stock rear drums on my car. it is a whirring sound, almost sounds like tire noise, but it isnt. kinda odd to explain the sound.
Old May 15, 2002 | 05:03 PM
EF'n's Avatar
maby there is a squirel that has his tail stuck up in there?
do your brakes work right? i have seen springs bust and rub but you would notice a difference in the pedal.
Old May 15, 2002 | 05:05 PM
Jared's Avatar
Default Re: help! (revhardracing)
see if you can isolate it to a certain side, most likely a bad wheel bearing
regal1975
Honda Civic (2006 - 2015)
Jan 7, 2012 02:55 PM
asianman139608
Jul 2, 2010 06:41 PM
lionhart
Dec 15, 2002 11:48 AM
