shiftlinkage has fallin after racing
well i have a crx w/hasport mounts and a 6 puck clutch and the other day the shift linkage fell down from the shifter side, the bracket bent so bad that the whole end fell down after hard shifting. Do you guys think my clutch is too much or my shift linkage should modified again?
your shift linkage has fallen and it can't get up??
i fought for a couple years with a set of modified shift linkages. after welding them back together 3 times.. i ended up buying the correct linkages and what do u know?? they work fine and aren't half as sloppy. there are crx sir linkages floating around. i came across a set by accident a few months ago. that's what i suggest.
