what ecu to use
Old Jan 16, 2007 | 05:49 PM
red beast's Avatar
Default what ecu to use
i have a 96 civic ex , just swapped a 92 ls in it what ecu or program should i use
Old Jan 16, 2007 | 05:56 PM
Brick Top's Avatar
Default Re: what ecu to use (red beast)
you should get a conversion harness from obd2 to obd1. and use an obd1 ls computer. assuming you rewired the ex harness.
Modified by brick top at 10:15 PM 1/16/2007
Old Jan 16, 2007 | 10:40 PM
Richard...'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red beast &raquo;</TD></TR><TR><TD CLASS="quote">i have a 96 civic ex , just swapped a 92 ls in it what ecu or program should i use</TD></TR></TABLE>
dosnt matter what obd1 ecu you use p28 p30 what ever it is just make sure and chip it and then put &lt;crome&gt; hondata on there
you can download a base map from the internet to get you started with all that but this has been covered a million times!
oh and do not forget the harness
oh and search is your friend!
Old Jan 17, 2007 | 09:50 AM
93turbo16's Avatar
If it is just a fairly stock car and you want to get it running well, just throw a stock OBD1 P75 in there with an OBD2 to OBD1 conversion harness like previously stated.
Or you could run the OBD2 P75 and jump some wires to get rid of the CKF code.
lampshadej1
Engine Management and Tuning
Jun 10, 2010 02:51 PM
Hazymix
Nov 20, 2006 02:59 PM
big-cat
26
Oct 19, 2006 11:14 AM
mountaindewguy
Mar 17, 2006 01:24 PM
weraider30
Dec 17, 2004 09:45 AM
