Alternator info needed. Everything went dim, then died. No warning lights on.
Old Jan 16, 2007 | 05:49 PM
951tom's Avatar
Default Alternator info needed. Everything went dim, then died. No warning lights on.
Driving home from work the lights were getting dimmer over a period of about 45 minutes. Eventually the car died and would not re-start. No warning lights came on except for the ABS light. So I swapped in a known good battery and it started right up and I was able to drive it 5 minutes to my house and parked it. Does this sound like the alternator is bad? The battery is 1 month old. I've been hearing a groaning sound from the alternator & p/s pump area too. You can hear the groaning while sitting in the car with it running. Any advice before I pull the alternator out? The car is a 1999 Accord V6 EX 4-door. Thanks in advance.
Tom
Old Jan 16, 2007 | 07:19 PM
gianinline's Avatar
Maybe your alternator is loosen, and then the accesories belt isn't turning the alternator, what you would get from that is pretty much what happened to you.
I think you need to check how loose your belt is....
Old Jan 16, 2007 | 07:56 PM
xluben's Avatar
Default Re: (gianinline)
get out the DMM and check if your voltage is 14V+ when the car is on.
also, check out the belt as mentioned above.
Old Jan 17, 2007 | 03:41 AM
951tom's Avatar
Just checked the belt and it's nice and tight. Once my battery is off the charger, I'll install it and hook up the DMM to see what voltage I'm getting. Thanks!
Old Jan 20, 2007 | 08:59 AM
951tom's Avatar
Battery was at 13.2 volts after the re-charging. With the engine running I'm seeing 12.3 volts at the battery terminals. R&R the alternator? Thanks
Old Jan 20, 2007 | 10:18 AM
Hawkze_2.3's Avatar
Default Re: (951tom)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 951tom &raquo;</TD></TR><TR><TD CLASS="quote">Battery was at 13.2 volts after the re-charging. With the engine running I'm seeing 12.3 volts at the battery terminals. R&R the alternator? Thanks</TD></TR></TABLE>
Yes, you should see 14+ volts. Check the alt. output at the alternator (the terminal with the nut holding the wire) and make sure you get 14+ there. If you don't, you can get the alt. tested for free at a local auto parts store and that way you can make sure you don't spend any $$ that you didn't have to.
Old Jan 21, 2007 | 04:26 PM
951tom's Avatar
Success! I took out the old alternator (not a difficult DIY project) and took it to Pep-boys. They tested it on there bench machine and it failed all 3 tests. With the new alt. installed, I'm reading 15.0 volts. Does this seem a little high?? Thanks!
Old Jan 21, 2007 | 06:45 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 951tom &raquo;</TD></TR><TR><TD CLASS="quote">Success! I took out the old alternator (not a difficult DIY project) and took it to Pep-boys. They tested it on there bench machine and it failed all 3 tests. With the new alt. installed, I'm reading 15.0 volts. Does this seem a little high?? Thanks!</TD></TR></TABLE>
Nice
15v should be fine....as long as it doesn't go higher than that.
ZenDog73
May 11, 2012 11:35 AM
maluseanjohn516
Jul 31, 2005 06:05 PM
KEVlN
Mar 15, 2003 10:07 PM
Old Skool
Mar 13, 2003 10:24 AM
onyx00
Dec 9, 2002 09:09 AM
