Del Sol Ignition System
Old Jan 16, 2007 | 01:00 PM
BSol18's Avatar
Default Del Sol Ignition System
I have a 93 del sol si that I recently swapped a B18A1 into...The swap went fine and everything was running great until my car was broken into a few months ago...Now, for some reason the starter wont engage....Battery is good, connections are fine, and the starter is pretty new...The car can be push started but I am losing power somewhere between the ignition switch and the starter. Is there anything i might have overlooked?
Old Jan 16, 2007 | 02:07 PM
gezzuzz's Avatar
Default Re: Del Sol Ignition System (BSol18)
did they break the ignition switch?
Old Jan 16, 2007 | 05:29 PM
BSol18's Avatar
Default Re: Del Sol Ignition System (gezzuzz)
I checked the switch over and nothing is broken or missing and all of the connections are good.
Old Jan 16, 2007 | 06:19 PM
EG2Driver's Avatar
look at the clutch relay switch situated right by your left foot when in driving position. It should be plugged in tight.....i disconnected mine when i first got my car and couldn't figure out why it didn't start.
Mitchel Perkins
Jul 24, 2017 07:32 AM
BaronVonZ
Feb 21, 2014 07:19 AM
lewis.robert
Oct 25, 2013 04:08 PM
prime-R
Mar 10, 2011 10:37 AM
