y7 or y8 head for turbo
Old Jan 16, 2007 | 12:49 PM
twism's Avatar
Default y7 or y8 head for turbo
wich is a better head for turbo i have the d16y8 in my car i have it running but the vtec wont work then i heard that the y7 head was better for turbo what are your thoughts
Old Jan 16, 2007 | 12:54 PM
EJ ITO's Avatar
Default Re: y7 or y8 head for turbo (twism)
do you have a check engine light?
Old Jan 16, 2007 | 01:02 PM
twism's Avatar
Default Re: y7 or y8 head for turbo (EJ ITO)
yes the cel is on i have a dx harness with a obd2B to A conversion harness with a p2p running it but it's not working right i also have a p75 wich it seems to run fine on haven't yet takin out on the road yet but i need to know if i should just say f-ck the vtec and just hook my turbo up with out it i also have a y7 head and i heard it would be a better head for turbo wich way should i go y8 with vtec that i cant get to work or y7 and wich ecu should i use p2p p75 p2e
Old Jan 16, 2007 | 01:05 PM
.Grimace's Avatar
footwork mastery
ok dumb question but... you said you have the conversion harness but did you wire up vtec?
Old Jan 16, 2007 | 03:16 PM
twism's Avatar
Default Re: y7 or y8 head for turbo (Gremice)
yes i wired up the vtec
Minime515
Apr 24, 2018 09:52 PM
welfarepc
Jan 7, 2007 03:18 PM
black7hatch
Nov 15, 2006 05:10 PM
ss20gsr
Feb 24, 2004 04:17 PM
xXx Justin xXx
Dec 21, 2003 10:54 AM
