How hard is it to install springs....
What special tools will I need? I know I need a spring compressor, but if I remember correctly there are two different types, which do I use? How long of an install is this for a competent first-timer? What problems will I run into? I've got a factory Helms, but it's geared more toward a technician than a enthusiast. I hope you guys that have done this before can help me out. Thanks.
The only special tool you will need is the compressor. Job goes a lot faster if you have air compressor tools as well. You'll need a 14mm 17mm 12mm and 10mm sockets and a another 17mm open end or socket. Everything is pretty straigh forward. I can do an entire car in about 2 hours. For a first timer look at maybe 4~6 hrs. Good luck.
pick up a honda manual for your car, it explains in detail how to install springs. if you can follow directions and have proper tools, you can install springs.
yeah i was thinking about doing this too, how much are spring compressors? where can i pick one up for a reasonable price? My friend used a wood clamp but it was DANGEROUS =P i don't want to mess around when i comes to springs =P
you really need a spring compressor, trust me if you dont feel like spending 8 hours trying to lower the lude, plus you can return them after your done.
i have a spring compressor here, If you wanna rent it, or even buy it, I'd be willing to sell it.
Lemmie know.
I live in the bay area up north.
Lemmie know.
It is pretty easy just takes time and patience.
mikeunreal
12
Nov 13, 2005 03:52 PM
chris215chris
Mar 19, 2003 04:35 PM
