b18c swap has begun!!
Old Jan 16, 2007 | 10:28 AM
I CRX I's Avatar
Default b18c swap has begun!!
im tearing down the old engine getting prepared to pull it out. Is there anything i need to be aware of before i start pulling hoses and disconnecting stuff?, ive already drained the coolant and oil, will the fuel be a problem, any help would be apreciated. Does anybody recall a problem they encountered when pulling there old eninge out?
Old Jan 16, 2007 | 12:11 PM
EF_338's Avatar
yes, encountered grimy build up everywhere
Old Jan 16, 2007 | 12:33 PM
needashell1234now's Avatar
Default Re: b18c swap has begun!! (I CRX I)
i wish i knew but when i do my swap in a few a months i'm going to be asking the same questions. good luck. take your time.
Old Jan 16, 2007 | 12:38 PM
ef9robert's Avatar
Make sure to take the tranny fluid out, when you remove the fuel line just vent it out first before completely removing it.
Issue i ran into was with the damn ac lines, but found out if you have the proper tool it not all that hard. :-)
Good luck..
Old Jan 16, 2007 | 01:09 PM
I CRX I's Avatar
well im not removing my AC so those are going to stay, but there are only 2 fuel line that have to be diconnected from the motor correct?
bonestock92si
Jul 21, 2008 07:49 PM
Jesterian
Aug 30, 2005 08:35 PM
eg6hatch
Jun 10, 2003 10:10 PM
400WHPITR
Apr 2, 2003 09:15 PM
