Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Rim sizing help
Old Jan 16, 2007 | 09:43 AM
1twojay's Avatar
Default Rim sizing help
I'm thinking about getting a set of Work Emotion CR KAI's for my JDM sedan. I'm going for 18" and i do plan on dropping the car a bit. Not too much though, the roads are really rough around here, so maybe 1.5 inches or so?
so would 18" x 7.5J work well without rubbing or bottoming out? What offset?
and I'm assuming 225/40/R18 tires would bode well?
Thanks for the help in advance!
Old Jan 16, 2007 | 10:01 AM
RICO_'s Avatar
NO MERCY!
Default Re: Rim sizing help (1twojay)
With a 1.5% drop you might bottom out on your fender if you take a bumpy turn, but other than that you should be fine. Just take the turn as straight as possible, turning the wheel after the bump if you can and you'll be fine.
Old Jan 16, 2007 | 10:30 AM
Nohawk's Avatar
Default Re: Rim sizing help (RICO_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RICO_ &raquo;</TD></TR><TR><TD CLASS="quote">With a 1.5% drop you might bottom out on your fender if you take a bumpy turn, but other than that you should be fine. Just take the turn as straight as possible, turning the wheel after the bump if you can and you'll be fine.</TD></TR></TABLE>
Do you mean 1.5 inches instead of %
Old Jan 16, 2007 | 10:32 AM
The Answer's Avatar
He may have.... but if he didn't it'd be a reasonable drop with 19's or 20's on your ride....
Old Jan 16, 2007 | 10:52 AM
Type X's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1twojay &raquo;</TD></TR><TR><TD CLASS="quote">I'm thinking about getting a set of Work Emotion CR KAI's for my JDM sedan. I'm going for 18" and i do plan on dropping the car a bit. Not too much though, the roads are really rough around here, so maybe 1.5 inches or so?
Thanks for the help in advance!</TD></TR></TABLE>
I was running 18x7 45mm with 225/40/18
with a 7.5 you SHOULD be ok..
as for the drop.. i was on comptech with SAYS 1" BUT.. settles way more
good luck.
Old Jan 16, 2007 | 10:59 AM
RICO_'s Avatar
NO MERCY!
Default Re: Rim sizing help (Si 4 Life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si 4 Life &raquo;</TD></TR><TR><TD CLASS="quote">
Do you mean 1.5 inches instead of %</TD></TR></TABLE>
lol. Yeah my fault. 1.5"
LOVE2HITVTEC
Aug 10, 2005 07:33 AM
jimmhatch
Jun 15, 2005 08:49 AM
deviant1
45
May 24, 2004 10:44 AM
EKhatch
18
Apr 10, 2004 12:50 AM
HondaMang
Mar 27, 2004 12:20 AM
