how to tell a Vtec head without a valve cover?
Old Jan 16, 2007 | 08:48 AM
ludecrasy87's Avatar
Default Noticing Vtec head
Ok my question is when you buyin the head of the engine and it vtec how can you tell without the valve cover?
Cuz wonderin due to my neighbor is doin his head swap on his f22b1 for a vtec head on the accord, now theirs people that will sell them but theirs no valve cover so how can you tell the differece between the two?
Old Jan 16, 2007 | 09:03 AM
02 accord's Avatar
Default Re: Noticing Vtec head (ludecrasy87)
A VTEC head will have 3 rockers for 2 intake valves. Non-VTEC only has one rocker for each valve.
This is my f23. Intake is on the far side. Notice the fat rocker inbetween the two skinnier ones (for each cylinder).
http://img88.imageshack.us/img...5.jpg
Old Jan 16, 2007 | 09:16 AM
rbpwrd240's Avatar
Ok i hope i dont run my mouth where it doesnt belong but if you look for the vtec sensore it will have to have one unless vtec is wired into a throttle position switch or somehting like that. The vtec sensor is at the back left corner of the head its about the size of a film canistor. it has two wires coming form the bottom of it and it bolts to the back of the head. Hope that makes sense.
Old Jan 16, 2007 | 12:15 PM
notoriousB's Avatar
Default Re: Noticing Vtec head (rbpwrd240)
02 accord is right - check the rocker assembly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rbpwrd240 &raquo;</TD></TR><TR><TD CLASS="quote">if you look for the vtec sensore it will have to have one unless vtec is wired into a throttle position switch or somehting like that. </TD></TR></TABLE>
this is very confusing, but I finally figured out what you mean - yep the vtec head will also have a vtec sensor (or holes for one) at the back by the dizzy mounting hole.
Old Jan 16, 2007 | 03:04 PM
hondadude's Avatar
look for the V-tec solenoid on the rear passenger side of the head.
Old Jan 17, 2007 | 02:46 PM
standbackimapro's Avatar
you can look on the left side of the head and see if it has a vtec solenoid
ludecrasy87
May 8, 2007 07:12 AM
dertymatt
May 2, 2005 08:01 AM
washpawryder
Nov 21, 2004 09:21 PM
SpoolinEK9
41
Mar 14, 2004 09:26 AM
fearthegerbil
Jul 9, 2003 11:48 PM
