more problems more money...i need help.
Guest
Posts: n/a
i have the h22a vtec. i had been running the p14 til i found a p13. i put it in and my car is now running really ruff...like it may not be getting enough spark or gas...like almost running in limp mode..anyone have any suggestions...no cels
I would think that the fact that it runs perfect on the h23 ecu but not on the h22 ecu and throws no CEL codes would be enough.
Car not working > some guy's word
Get some h22 injectors and try them, its not like they're that hard to find...
Guest
Posts: n/a
if you are running an OBDI ecu and a resistor pack, you need OBDI h22 injectors which are low impedance (peak and hold). The injectors in that ebay auction are saturated. If you wanted to run those injectors you would have to remove the resistor pack, cut the injector clips off and solder OBDII injector clips on.
do this. Find a way to measure the diameter of the injector body (the gut of the injector).
Guest
Posts: n/a
hey do i need a fpr with these injectors..will my car be getting to much gas with these..
http://cgi.ebay.com/ebaymotors...&rd=1
luvinthelude
Jul 30, 2013 05:27 PM
