Honda S2000 Honda S2000
***LETS TALK SPRING RATES***
Old Jan 15, 2007 | 05:50 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default ***LETS TALK SPRING RATES***
ok thought this would be a good one for some tech in here...
spring rates we all know they play a major factor with how a car performs.. share your thoughts,ideas and spring set ups...
my Buddy Clubs have 10F 10R
my Function Forms have the standard 10F 8R
considersing going 10/10 again even maybe 12/12 .....
Old Jan 15, 2007 | 06:49 PM
immortal's Avatar
Banned
Default Re: ***LETS TALK SPRING RATES*** (S@nt0s)
if you are going to run that stiff of spring rates on the street, i highly recommend getting swift springs. they are much more bearable because of the design and material they are made out of. they are much more linear springs that have their rate measured from 20-80% of their stroke unlike a lot of other coilovers advertise.http://www.swiftsprings.com you should check out their website and learn about them.
i currently have spoon dampers /w swift mach springs that have rates around 5-6kg front/rear .. eventually i'm going to get the spoon adj coilovers with swift springs 10kg f/r. anything past 10-12 on street is overkill and not worth it unless you track your car every single weekend and daily on the weekdays. unless you like your guts rattled around daily
Old Jan 15, 2007 | 06:59 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: ***LETS TALK SPRING RATES*** (immortal)
yea i knwo about Swift.... they are great springs... and i dont want to say anything but swift spring are the choice for mine if i decided to change the rates again...
Old Jan 15, 2007 | 08:20 PM
Francesco's Avatar
I have 8k zeals in all four corners. Im pretty sure swift makes the springs for zeal/endless.
I personally feel my 8k zeals are stiffer than the 10/12 tein flex I had before.
I want to get a better set of coilovers though with higher valving so I can run a 14/14 or 16/16. Possibly arogasta or j's. I cant justify Motons for a street car.
Old Jan 15, 2007 | 08:25 PM
MaskedAP1's Avatar
how do you like the 10K all around spring rate S@nt0s ? whats your other suspension mods?
im considering get a BC RS as well, but dunno if the 10K all around spring rate suit my need.if not, i will get a swift custom rate spring and match my setup.
i have only spoon front tower bar and a UK spec alignment on my 00 AP1 now, but im getting cusco 32mm front sway bar, spoon front x brace and spoon rear lower tie bar. what kinda of spring rate do you guys recommanded? the main aim is track use, and i dont mind stiff
Old Jan 15, 2007 | 08:41 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: ***LETS TALK SPRING RATES*** (MaskedAP1)
MaskedAP1,
the 10K is kool with me man.. on days im moody i just set the struts soft.. but im usually 8+ on the f/r's.....
other then the coilovers i have a safety21 4 point with harness bar... i plan on getting a X brace and thats pretty much it i think....
Old Jan 16, 2007 | 08:57 AM
Mr. Projekt's Avatar
* B A N N E D *
Get a set of 12s and a set of 10s from Swift, and play switcharound. The BCs damping curve is on the stiff side, so I'd try 12/10 first and see if I have to stiffen up the rear.
http://forums.s2000turbo.com/viewtopic.php?t=584
Rear-biased stiffness is covered, and not recommended.
Old Jan 16, 2007 | 09:40 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: ***LETS TALK SPRING RATES*** (Mr. Projekt)
but im not on the BC's no more.. but the functions are on the stiff side as well....
this is just a open dicussion for everyone to share their rates adn ideas...
Old Jan 16, 2007 | 10:00 AM
* B A N N E D *
Spring rate has to match shock valving, chassis weight and balance, and tire specs. Even with 50/50 balance in our car, 14/12 or 13/11 is a common recommended spring rate. Running equal front and rear spring rates usually makes the rear end unload faster, adding to the snap oversteer problem.
Old Jan 16, 2007 | 10:17 AM
* B A N N E D *
https://honda-tech.com/zerothread/1104049
Old Jan 16, 2007 | 11:46 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
as stated above about the swift springs.. Function form will now offer the swift springs with the set up... so i need to upgrade now!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Projekt &raquo;</TD></TR><TR><TD CLASS="quote">Spring rate has to match shock valving, chassis weight and balance, and tire specs. Even with 50/50 balance in our car, 14/12 or 13/11 is a common recommended spring rate. Running equal front and rear spring rates usually makes the rear end unload faster, adding to the snap oversteer problem.</TD></TR></TABLE>
yes that is so!
im considering a 12/10 possible or 12/8.. with the 8 rear it may help settle it.. or just stay 10/8
Old Jan 16, 2007 | 11:48 AM
* B A N N E D *
12/10
We get more brake dive than accel-squat, but 8 is too soft.
Old Jan 16, 2007 | 11:52 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Projekt &raquo;</TD></TR><TR><TD CLASS="quote">12/10
We get more brake dive than accel-squat, but 8 is too soft. </TD></TR></TABLE>
i guess no one else likes to talk suspension.....
Old Jan 16, 2007 | 11:54 AM
* B A N N E D *
The e-racers post but don't have real world experience. The real-racers have experience but don't post. That leaves it to us back-yard mechanics.
Old Jan 16, 2007 | 12:01 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Projekt &raquo;</TD></TR><TR><TD CLASS="quote">The e-racers post but don't have real world experience. The real-racers have experience but don't post. That leaves it to us back-yard mechanics.
yea we are in the happy medium.... track and street ******..... hoping to make a track session this spring with the S.... but until then killin canyons and on/off ramps
Old Jan 16, 2007 | 12:02 PM
* B A N N E D *
I been waiting for your *** to track with us man. Get a clutch and lets go.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Me on S2000 Turbo &raquo;</TD></TR><TR><TD CLASS="quote">14) Returning to what happens on the track - a rear stiff car will unload the inside rear faster than it unloads the inside front. At some point all of the inside rear weight has been transferred to the outside rear. A rear camber setting is selected so that at the terminal roll angle of the chassis sufficient grip is generated by the outside rear alone. This is typically achieved on our cars at something less than the camber required to generate the maximum potential rear grip. As the outside rear decambers in roll, and converges on its terminal camber, it is generating greater and greater grip - both as the vertical force increases from weight transfer, and as the dynamic camber improves. At the kind of rear spring rates common to both NA and JDM setups, dynamic rear camber change during rear weight transfer in pure roll is approx +1 degree (decambering). In any case the front decambers approx 50% faster than the rear in pure roll while all four wheels are on the ground. Since we rarely have pure roll without pitch effects we should note that the combined effects camber curves are a more complex story that must be examined in cases. Most interesting among these is drop throttle behavior. The rear decambers fast in combined roll and droop. This points to the usefulness from this perspective of high rear spring rates in general as common to both setups. Generally speaking, as we converge on max lateral acceleration we converge on optimal dynamic camber - assuming we're doing our job as a race engineer. In general camber change is not something to be minimized for it's own sake (the chassis performance envelope is a multi-dimensional topography - very little about it can be changed without affecting other perhaps more important factors) - the JDM guys don't do what they do simply to control front dynamic camber. </TD></TR></TABLE>
Old Jan 16, 2007 | 12:10 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Projekt &raquo;</TD></TR><TR><TD CLASS="quote">I been waiting for your *** to track with us man. Get a clutch and lets go.
yea i know bro!!!
i just noticed too that i need to replace my right front endlink since its broken now...
now that we bring up de-cambering..
se eim going to be running 2 front 3 rear that is why i was considering doign the 12 rear or just sticking with the 10.....
soft damping settings on the street with turn the **** at the track....
Old Jan 16, 2007 | 01:13 PM
SilverDc2's Avatar
how are the buddy clubs? i can't deciede if i want those or the bilstein pss9s
Old Jan 16, 2007 | 01:16 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: ***LETS TALK SPRING RATES*** (SilverDc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverDc2 &raquo;</TD></TR><TR><TD CLASS="quote">how are the buddy clubs? i can't deciede if i want those or the bilstein pss9s
they are good bro i have ZERO compliants about them..
Old Jan 16, 2007 | 02:43 PM
aplus2k's Avatar
I'm running the JIC FLTA-2's with 12/10 setup.
Old Jan 16, 2007 | 03:35 PM
Nishant's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Projekt &raquo;</TD></TR><TR><TD CLASS="quote">The e-racers post but don't have real world experience. The real-racers have experience but don't post. That leaves it to us back-yard mechanics.</TD></TR></TABLE>
andretired old guys like myself
Old Jan 16, 2007 | 04:58 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: ***LETS TALK SPRING RATES*** (Mr. Nishant)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Nishant &raquo;</TD></TR><TR><TD CLASS="quote">
andretired old guys like myself </TD></TR></TABLE>
if your old then i need to start collecting SS...
Old Jan 16, 2007 | 08:20 PM
Francesco's Avatar
I hear the BC's blow out fast. My friend has been through two rear coilovers in under a year. Their good for the money, but theirs better set ups out there.
rofl.
you get a new car yet?
Old Jan 16, 2007 | 08:21 PM
Francesco's Avatar
you forgot the on ramp/ off ramp mobsters
Old Jan 17, 2007 | 09:46 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: ***LETS TALK SPRING RATES*** (Francesco)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Francesco &raquo;</TD></TR><TR><TD CLASS="quote">
you forgot the on ramp/ off ramp mobsters </TD></TR></TABLE>
we talked about that in another thread too...
