clutch?
Old Jan 15, 2007 | 03:44 PM
sazdasl's Avatar
Default clutch?
I am needing to order a clutch and flywheel for my si with a b16a. I just dont know which car would i go about ordering it for? Do i order it for a car that came stock with a b16a or do i order one for the stock si?
Old Jan 15, 2007 | 04:19 PM
dr_latino999's Avatar
Default Re: clutch? (sazdasl)
What transmission are you running?
Old Jan 15, 2007 | 04:48 PM
sazdasl's Avatar
js1 tranny
Old Jan 15, 2007 | 04:51 PM
Mr. Giggles's Avatar
[QUOTE=sazdasl]I am needing to order a clutch and flywheel for my si with a b16a.QUOTE]
When you decide to buy your clutch and flywheel, go with ebay.
I got my exedy cluth and fidanza flywheel for $260 shipped
user 72830283's Avatar
order it for the 96+ Si's ...all b-series tranny's have interchangeable clutch/flywheels...
Old Jan 15, 2007 | 05:02 PM
sazdasl's Avatar
Default Re: (pr3d)
cool! kinda figured a bseries clutch is what i would be going after! thanks!
Old Jan 15, 2007 | 05:17 PM
Default Re: (pr3d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pr3d &raquo;</TD></TR><TR><TD CLASS="quote">order it for the 96+ Si's ...all b-series tranny's have interchangeable clutch/flywheels...</TD></TR></TABLE> Wrong on two counts
Del Sol VTEC for 96-97
Civic SI 99-00
Also, some cable transmissions had a different sized input shaft. Let me check my guide to figure which for which.
~Runs back to watching 24~
Old Jan 15, 2007 | 05:30 PM
Default Re: (dr_latino999)
Ok, early model Cable transmissions have a 25mm input shaft, later transmissions have a 26mm input shaft. Hopefully we can get the tranmission guru's in here to give an exact reference.
Old Jan 15, 2007 | 06:05 PM
Creator's Avatar
I have a B16 JDM tranny on mine and ended up getting a 90-91 LS clutch.
Actually I had burnt up my first one which I believe was a YS1 and the one on it now I believe is a J1...no telling cause the crappy little identification stickers on both where missing. I based my conclusion on what the trannys where on the short gearing.
Old Jan 17, 2007 | 04:12 AM
sazdasl's Avatar
bump? anyone else have some more info?
Old Jan 17, 2007 | 05:59 AM
civic_jdm16's Avatar
Default Re: (sazdasl)
Yes all B series fly wheels are the same. is goes by tranny cable or hydro.. they are different spline and the pressure plates are different order the clucth by tranny!!
Old Jan 18, 2007 | 06:34 PM
sazdasl's Avatar
so with my J1 tranny i should order a clutch for a 90-91 integra?
Old Jan 21, 2007 | 03:53 PM
sazdasl's Avatar
would this clutch work?
http://cgi.ebay.com/ebaymotors...QrdZ1
it says it is for the y1 and s1....shouldnt it also work with the j1?
raphael
Nov 4, 2009 07:55 PM
Clipsed
Sep 11, 2008 09:17 AM
daidilus
Jan 6, 2006 04:59 AM
clemsonhatch
Jun 19, 2003 04:25 PM
