H22 Vs H23 Boosted
I was wondering which engine is better for boost non vtec or vtec h22 or h23 some people tell me the non vtec is better for boost because its a bigger block and it has less compression but i figured since the h22 has 200hp adding turbo will make it faster than 160hp non-vtec
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skylude23 »</TD></TR><TR><TD CLASS="quote">I was wondering which engine is better for boost non vtec or vtec h22 or h23 some people tell me the non vtec is better for boost because its a bigger block and it has less compression but i figured since the h22 has 200hp adding turbo will make it faster than 160hp non-vtec</TD></TR></TABLE>
The H22 will produce more whp if you use the same turbo. But the H23 will handle boost better because of the lower compression and the tranny is also a little bit better.
remember faster is not always better
BLACK_DEL_SOL
Aug 19, 2004 04:44 AM
