Calling out all backyard mechanics!
Old Jan 15, 2007 | 02:06 PM
djrev's Avatar
Default Calling out all backyard mechanics!
Problem: When releasing the clutch pedal quickly I get a grinding/rubbing metal sound. It only happends if I let the cluctch out quickly (no dumping or burning out). Kind of when you do a sloppy start, during that initial jerk of the car, the sound is preatty bad. But after the car starts rolling its gone. If I release the clutch out on slowly there is no sound or any any other gear for that matter. I lifted my car and inspected for any rubbing, grinding, shaved areas. Visually I could see none. So I took out the axel and still cant see any wear or anything. I took some pics to see if you guys can spot anything I'm missing. The axels is not an OEM piece, and was purchased through a local import shop.
Modified by djrev at 4:30 PM 1/15/2007
Old Jan 15, 2007 | 02:57 PM
Anti-Drama Queens's Avatar
do u have a staged clutch?
Old Jan 15, 2007 | 03:15 PM
xsiteggy's Avatar
Default Re: Calling out all backyard mechanics! (djrev)
check those axles again make sure the bearings are not coming out of the casing...hard to see cuz of the boot still being in tact....
Old Jan 15, 2007 | 03:29 PM
djrev's Avatar
I replaced the clutch a little under two years ago with an Exedy Organic OE replacement w/pressure plate also. At that sime time I replaced the axel (with the non-oem)...and the sound is only on that passenger...
Old Jan 16, 2007 | 06:45 PM
djrev's Avatar
bump for help...
Old Jan 20, 2007 | 05:53 PM
djrev's Avatar
bump for a quick moving tech section....
osix
Dec 13, 2015 08:28 AM
Killspeed93
Sep 1, 2011 06:32 AM
headrec*
Transmission & Drivetrain
Aug 29, 2008 08:49 PM
IBriaIN
Aug 12, 2008 08:09 AM
