VSS Speed Sensor OR Speed Pulser?
Old May 15, 2002 | 10:41 AM
rschoener's Avatar
Default VSS Speed Sensor OR Speed Pulser?
VSS Speed Sensor OR Speed Pulser? are they the same signal? I swapped a D16Z6 with the P28 ECU into My 89 Civic DX. I do not have a Speed sensor on the trans. There is a wire for speed Pulser? is that the same thing? if not how could i hook this up. My Vtec has not come on yet and the only Code i get is for the speed sensor. Thanks for any help..
Old May 15, 2002 | 11:36 AM
kinesistech's Avatar
Default Re: VSS Speed Sensor OR Speed Pulser? (rschoener)
I believe that wire works. The 88-91 b16's had to get it from somewhere right.
[Modified by kinesistech, 8:36 PM 5/15/2002]
Old May 16, 2002 | 07:32 AM
rschoener's Avatar
Default Re: VSS Speed Sensor OR Speed Pulser? (kinesistech)
Thanks It worked..
fcm
Nov 4, 2014 05:32 PM
blaze.1
Sep 10, 2009 06:24 AM
rnbguy
Oct 25, 2008 10:36 AM
