98 DX idle/IACV problem
Old Jan 15, 2007 | 01:12 PM
SHG_Mike's Avatar
Default 98 DX idle/IACV problem
Well ive been battling a extremely annoying idle prob for the past month or so. I start the car revs shoot up to 2300rpms thne go down to 1400 then go back up to 1800 kinda bounces a round a bit ten settles around 1700. Then is i put a load on it itll rev up to 2100 rpm and just chill there. I replaces the IACV bled the coolant messed with the idle screw and the FICV. So i decided to plug up the IACV hole in the TB and what do you no, beautiful idle at 750 RPM's. I have no AC or PS, is there any downside to pluging the IACV and just running at a 750-850 idle? Or what else could my problem be?
Old Jan 15, 2007 | 01:15 PM
gezzuzz's Avatar
Default Re: 98 DX idle/IACV problem (Knappster)
do this... take the vacuum hose off the intake mainfold that goes to you your brake booster plug the hole..
Old Jan 15, 2007 | 01:31 PM
SHG_Mike's Avatar
Default Re: 98 DX idle/IACV problem (gezzuzz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gezzuzz &raquo;</TD></TR><TR><TD CLASS="quote">do this... take the vacuum hose off the intake mainfold that goes to you your brake booster plug the hole.. </TD></TR></TABLE>
that would do what besides give me 0 braking power?
Old Jan 15, 2007 | 01:35 PM
gezzuzz's Avatar
it would test if air in leaking the thru there.. don;t drive like that
Old Jan 15, 2007 | 02:18 PM
SHG_Mike's Avatar
ah, gotcha, yea i know i wouldnt drive it like that.... ill give it a shot
Mike Heath
Feb 21, 2018 02:44 AM
footstinker
Nov 6, 2010 01:09 AM
wilrock
Apr 4, 2006 05:56 PM
SHG_EasyE
Apr 2, 2006 08:10 PM
ponykillergsr
Dec 20, 2002 06:01 AM
