***HELP**** Seriously read should be easy question for one of you pros ***HELP***
Old Jan 15, 2007 | 01:04 PM
1SickEG's Avatar
Default ***HELP**** Seriously read should be easy question for one of you pros ***HELP***
instead of replacing my d16y8 with a replacement motor i put a d15b vtec into a 96 ek shell...converted everything to obd1....such as injectors/jumper harness/and a ex wiring harness(engine harness)...i crank the car and it runs but misses and has a 1800-2000 redline.....does anyone know what my problem is? im running a obd1 ecu and everything...ive got a feeling the tps sensor may be bad..but although im thinking in my head i didnt wire something up..can anyone help? thanks
Old Jan 15, 2007 | 01:21 PM
1SickEG's Avatar
bump need help asap
Old Jan 15, 2007 | 01:29 PM
gezzuzz's Avatar
Default Re: ***HELP**** Seriously read should be easy question for one of you pros ***HELP*** (1SickEG)
are you getting a check engine light?
beaneg6's Avatar
Default Re: (1SickEG)
will the car stay on? could be map sensor...
Old Jan 15, 2007 | 01:30 PM
gezzuzz's Avatar
Default Re: (beaneg6)
high redline mean you have a vac leak
Old Jan 15, 2007 | 01:50 PM
B18CivicEH2's Avatar
Default Re: (gezzuzz)
what??you redlining at about 2k RPM's???so that means you have an avarage of 1-1.5k RPMs per gear???am i understanding that correctly??
Old Jan 15, 2007 | 01:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SickEG &raquo;</TD></TR><TR><TD CLASS="quote"> it runs but misses </TD></TR></TABLE>
if you mean its misfiring, make sure your plugs are one correctly...
Old Jan 15, 2007 | 01:55 PM
gezzuzz's Avatar
Default Re: ***HELP**** Seriously read should be easy question for one of you pros ***HELP*** (B18CivicEg)
you said 2000rpm redline.. thought you said idle... im blind
check that!!
Old Jan 15, 2007 | 06:45 PM
1SickEG's Avatar
the plugs are right...its running good now its not misfiring but if u rev the engine up a little it will just bounce at 1800-2000 redline? anyone please help we tried messing with the tps sensor tonight but it seems to be doing fine?
Old Jan 15, 2007 | 06:48 PM
try a different ECU..
Old Jan 15, 2007 | 06:56 PM
EJgsr's Avatar
Default Re: (B18CivicEg)
is your ECU an auto?
Old Jan 15, 2007 | 06:57 PM
1SickEG's Avatar
no it came out of a del sol with a d16z6....i have no idea wtf is up..maybe trying a different ecu will work..ill let u guys know any more ideas will greatly help!
Old Jan 15, 2007 | 07:51 PM
DrewMD's Avatar
Davis Photography
you said you cant rev it past 2k? or you can it just idles back and forth between like 1.5k and 2k rpm? if so then you have a vacumm leak or you need to clean your IACV or the Fast Idle Control.
Old Jan 15, 2007 | 08:10 PM
JdmEj1!'s Avatar
Default Re: (DrewMD)
he just cant rev past 2k.... check your ecu.. automatic ecus wont let u rev past around that much....
v.ice1
Jul 4, 2010 09:27 PM
gsr96cx
May 19, 2009 08:05 PM
98jdmek
May 7, 2007 10:56 AM
