what map sensor to use with b16a
i have read that you use the stock crx map sensor for a b16a swap. but i also read that you use the b16a map sensor and that you will run a little rich if you run the crx map sensor. anyone know what one to use, and are there alternatives available?
The map sensors are the same between the motors, the only difference you'll ever have is if it is firewall mounted or mounted directly to the throttle body.
velisma
Feb 6, 2009 06:08 AM
GeeSeeR
Aug 15, 2001 09:27 PM
