Oil leak from oil pan drain plug
Old Jan 15, 2007 | 11:49 AM
1EGdude's Avatar
Default Oil leak from oil pan drain plug
Hi, I need some help with my 1992 Civic CX hatchback stock motor. I have an oil leak in the oil drain plug. I already went to the dealership and bought a new washer and drain plug, but it still leaks oil? Any help would be appreciated. Thanks in advance.
Old Jan 15, 2007 | 12:09 PM
b18bturbo's Avatar
Default Re: Oil leak from oil pan drain plug (1EGdude)
probbaly the threads are stripped and not sealing properly are you sure its the drain plug and not hte oil pan seal.
only alternative is to clean the thread and check and or get a new pan
Old Jan 15, 2007 | 01:33 PM
bart2546's Avatar
Default Re: Oil leak from oil pan drain plug (b18bturbo)
Before having to jump to a new pan, you could use a tap and die set to create new threads.
Old Jan 15, 2007 | 02:33 PM
99B16Si's Avatar
try some teflon tape
Old Jan 15, 2007 | 02:47 PM
biotech0123's Avatar
Default Re: (99B16Si)
tried all those above and still dealing with it, buy a new pan.
Old Jan 16, 2007 | 09:14 AM
1EGdude's Avatar
Thank you for your responses. I think it will be easier to just replace it the oil pan, then trying to solve that leak.
Old Jan 16, 2007 | 11:19 AM
BuddhaSiR's Avatar
if you dont want to replace your pan you can have a thread insert put in.
http://www.timesert.com/html/honda.html
Only problem is finding someone with that kit to do the repair. You could buy the kit if you plan on repairing other peoples stripped threads. The money you make from repairing oil pans could pay for the kit.
Old Jan 18, 2007 | 04:51 PM
Fabman's Avatar
Lierley Fab
Default Re: Oil leak from oil pan drain plug (BuddhaSiR)
99b16si is a stand up guy
Modified by Fabman at 2:52 AM 1/19/2007
sparkyk20eg
K Series
Aug 22, 2018 08:01 PM
jdmda_1.7a
Feb 15, 2011 07:35 AM
tamadrumr88
Dec 24, 2009 04:34 PM
mitch3814
Apr 5, 2005 06:37 PM
92preludeSI
Mar 10, 2003 07:33 PM
