CRX SWAP QUESTION
Old Jan 15, 2007 | 10:19 AM
crx noob's Avatar
Default CRX SWAP QUESTION
CAN A D15B VTEC OUT OF A 92 CIVIC SWAP INTO A 90 CRX DX IF SO WHAT CHANGES NEED TO BE MADE AND IS IT WORTH IT
Old Jan 15, 2007 | 10:21 AM
ILcrxsi1's Avatar
I tell doctors what to do
Default Re: CRX SWAP QUESTION (crx noob)
yes it can. search for the rest of the answers
Old Jan 15, 2007 | 10:27 AM
crx noob's Avatar
THANKS FOR THE QUICK REPLY
IS IT WORTH THE SWAP
Old Jan 15, 2007 | 10:36 AM
crxnj's Avatar
Default Re: (crx noob)
imo no. you're going from a 1.5 sohc to a 1.5 sohc..
Old Jan 15, 2007 | 10:40 AM
charlee's Avatar
Default Re: (mr.speaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">imo no. you're going from a 1.5 sohc to a 1.5 sohc..</TD></TR></TABLE>
power wise, no gain if you plan to keep the stock ecu. As a replacement for a blown motor it would be good
Old Jan 15, 2007 | 11:10 AM
dephtone's Avatar
the d15b vtec is way better than the Dual Point that comes stock. a. d15b vtec is Multi Port. b/ probably look at an extra 20 hp or so couple ft lbs of tq. If you get everything and do it right I don't see why it wouldn't be worth it. As long as you did it RIGHT. Conversion harnesses, etc
Old Jan 15, 2007 | 11:24 AM
ILcrxsi1's Avatar
Default Re: (dephtone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dephtone &raquo;</TD></TR><TR><TD CLASS="quote">the d15b vtec is way better than the Dual Point that comes stock. a. d15b vtec is Multi Port. b/ probably look at an extra 20 hp or so couple ft lbs of tq. If you get everything and do it right I don't see why it wouldn't be worth it. As long as you did it RIGHT. Conversion harnesses, etc</TD></TR></TABLE>I agree
Old Jan 15, 2007 | 11:55 AM
crxnj's Avatar
Default Re: (ILcrxsi1)
he'd be better off just doing a mini-me,and run turboedit 1-wire vtec with d15b vtec fuel and timing maps,,same **** and cheap,all he would have to do is find an obd0 mpfi distributor...
you dont really gain 20hp either..mpfi d15b2 or a d15b vtec or d15b2 mini-me you're looking at around 100 whp on all with the proper ecu,,and 15 second 1/4 miles with all,,so i dont see how its worth it to do it right meaing conversion harnesses,obd1 ecu and all that..but maybe he doesnt care about performance and is getting the motor dirt cheap as a replacement,not really sure what he wants.
Old Jan 15, 2007 | 12:25 PM
ILcrxsi1's Avatar
you dont really gain 20hp either..mpfi d15b2 or a d15b vtec or d15b2 mini-me you're looking at around 100 whp on all with the proper ecu,,and 15 second 1/4 miles with all,,so i dont see how its worth it to do it right meaing conversion harnesses,obd1 ecu and all that..but maybe he doesnt care about performance and is getting the motor dirt cheap as a replacement,not really sure what he wants.</TD></TR></TABLE>Yeah but if you buy the d15b from hmotors you pretty much get everything you need. Ecu, distributor, etc. All you need after that is an obd1 conversion harness since the p08 ecu uses a 1 wire 02 sensor anyway. Then you have the turn key reliability of a stock motor.
Old Jan 15, 2007 | 12:44 PM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILcrxsi1 &raquo;</TD></TR><TR><TD CLASS="quote">Yeah but if you buy the d15b from hmotors you pretty much get everything you need. Ecu, distributor, etc. All you need after that is an obd1 conversion harness since the p08 ecu uses a 1 wire 02 sensor anyway. Then you have the turn key reliability of a stock motor.</TD></TR></TABLE>
how do you like your d15b?
Old Jan 15, 2007 | 12:52 PM
ILcrxsi1's Avatar
how do you like your d15b?</TD></TR></TABLE>eh, it could be faster. It needs a snail . It pulls hard in the high rpms, oh wait it's a honda
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILcrxsi1 &raquo;</TD></TR><TR><TD CLASS="quote">eh, it could be faster. It needs a snail </TD></TR></TABLE>
the one i thing i do like about them is how they rev.
Old Jan 15, 2007 | 01:05 PM
ILcrxsi1's Avatar
the one i thing i do like about them is how they rev.</TD></TR></TABLE>mine has had countless run-ins with the rev limiter, which on that ecu is 7800 I think. It handles it with no problem
cameronvickrey
May 9, 2005 05:27 PM
^Sammy]!.
Feb 11, 2005 08:36 PM
RussHondaCRXVtec
11
Oct 7, 2003 10:45 AM
Tsunami
27
May 5, 2003 03:42 AM
lonefuzzy79
12
Feb 5, 2002 12:06 PM
