Could an aftermarket PCV valve be screwing up my idle?
Old Jan 15, 2007 | 06:25 AM
justint's Avatar
Default Could an aftermarket PCV valve be screwing up my idle?
My oem valve on my B20 wasn't working and I had to switch it out quickly with a Purolator one from the auto parts shop. Since then, my car has been having idle issues, low idle, stalling at idle. Could the valve be the issue?
Old Jan 15, 2007 | 08:10 AM
Flexmyrex's Avatar
Default Re: Could an aftermarket PCV valve be screwing up my idle? (justint)
A pcv valve is calibrated to adjust/respond to different vacuum/atmospheric conditions, there is no standard way to calibrate them so yes it could be a possible source to your problem, especially since it started happening right after you put one in.
I would also check the iacv.
Old Jan 15, 2007 | 08:39 PM
YoungKadafi's Avatar
ive been using one for a while, and i dont think it has anything to do with that, however, i put a Different PCV valve, from a different car which looked the same, this messed things up big time, i guess the spring and shape is different, but im probably wrong, because all it is, is a check valve, im going to make my own and let you know if its any different
Old Jan 15, 2007 | 08:46 PM
justint's Avatar
Default Re: (YoungKadafi)
I changed out my PCV valve tonight for an OEM one and my Idle is back to normal!!! nor more after market parts for me.
Old Jan 15, 2007 | 11:00 PM
you mean the one from honda dealership? or the oem type from checker or something?
Zaraki
Jun 22, 2013 08:57 PM
turbo_d16
Jun 18, 2011 10:22 AM
rpmraper
Jun 11, 2011 10:53 AM
Praetor353
Apr 28, 2009 03:59 PM
sleepyone
Dec 11, 2008 09:17 AM
