205/40/17 tires on 17x8
Old Jan 14, 2007 | 11:18 PM
smubzi's Avatar
Default 205/40/17 tires on 17x8
205/40/17 tires on 17x8 42mm offset ( Lowered 1.7" Tein S-tech) for 1997 civic EX coupe.
Let me know what you think, if these works with rubbing.
Thanks!
Old Jan 14, 2007 | 11:40 PM
vtecsi00's Avatar
Default Re: 205/40/17 tires on 17x8 (smubzi)
i thought we had answered your question already on this subject for you???
if you want to know if the wheel will work then you are going to have to do some leg work... take a tape measure and measure 6.15 inches from your hub to your suspension.. if nothing hits then you are ok.... now take the tape measure and measure 2.85 inches from the hub to your fender... if it doesn't hit the fender the you should be ok all the way around..........
Old Jan 15, 2007 | 05:34 AM
smubzi's Avatar
Default Re: 205/40/17 tires on 17x8 (vtecsi00)
thanks, just wanted to make sure before i get the stuff.
Old Jan 15, 2007 | 06:32 AM
smubzi's Avatar
one thing, i also want to make sure if 205/40/17 tire will work fine on the 8" wide rims, cause I read some forums that it will look horrible because the tire will be stretched out, and it might blow up easily. please need help guys I really like the rims, its motegi lc5 4x100, 17x8 for only $300 (set) brand new. do you think its a good deal? or
let me know, Thanks!!!
Old Jan 15, 2007 | 05:37 PM
HondaF1Fanatic's Avatar
Whoever told you that is full of ****, as long as it is within the manufacturers approved specifications you are fine. Will it be slightly easier to scratch your rim if you curb it? Yes. Will your tire look stretched on a VW ghey? No. Will your tire be prone to spontaneous explosions? Absolutely not, unless you stick explosives in it. Sounds to me like someone with serious cranial-rectal inversion disorder was giving you advice.
Jon
Old Jan 15, 2007 | 05:44 PM
vtecsi00's Avatar
Default Re: 205/40/17 tires on 17x8 (HondaF1Fanatic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaF1Fanatic &raquo;</TD></TR><TR><TD CLASS="quote"> Will your tire be prone to spontaneous explosions? Absolutely not, unless you stick explosives in it. Sounds to me like someone with serious cranial-rectal inversion disorder was giving you advice.
Jon</TD></TR></TABLE>
no that is funny.... thanks HondaF1Fanatic
but on the real side of this it will be fine.. the guys at the shop will definitely have fun airing your tires up thou... enjoy your wheels definitely a good buy...
Old Jan 15, 2007 | 05:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecsi00 &raquo;</TD></TR><TR><TD CLASS="quote">
I find nothing wrong with making people earn their paycheck lol, but it will be a PITA for them. At the same time, I can't see any tire being as difficult to mount as the RE070s on my STi were, I swear it took the guys at Discount almost 3 hours to get them done from the time my car went up on the lift........
Jon
Old Jan 15, 2007 | 06:10 PM
smubzi's Avatar
thanks for the input guys, i'll be getting the rims tonight. and probably i'll get the Kumho Ecsta SPT 205/40/17. I really like the rims, I cant wait to put em on my car.
Old Jan 15, 2007 | 06:16 PM
smubzi's Avatar
here's the link to the rims, please check it out and let me know what you think.
Modified by smubzi at 10:00 PM 1/15/2007
Old Jan 15, 2007 | 11:06 PM
vtecsi00's Avatar
must not of been using the right machine for your tires... i put them on in no time at work....
cooldudeness
Jun 16, 2007 04:00 PM
Integra21
Jun 23, 2005 09:18 PM
Accord98
May 22, 2003 10:59 AM
h22accordturbo
Oct 29, 2002 10:04 AM
zojirushi
Jan 15, 2002 03:52 PM
