compression ratio
Old Jan 14, 2007 | 09:26 PM
ontheline's Avatar
Default compression ratio
one of my friends told me if i put in new cams i would have to change my compression ratio. is this true? im planning on picking up some mx22 for use in a jdm b18c5
Old Jan 15, 2007 | 12:46 AM
b19coupe's Avatar
Default Re: compression ratio (ontheline)
No, it is not true. A large cam like a Skunk Pro 3 won't be ideal for a 10:1 1.8 liter GSR motor, but you do not need a 14:1 2.1 liter race gas only monster to run cams larger than ITR's.
Old Jan 15, 2007 | 05:18 AM
gibsanez's Avatar
Default Re: compression ratio (b19coupe)
the m22x(x) are a fairly long duration cam, and you'll loose some dynamic compression ratio unless you bump up through milling/decking/pistons/valves.
Old Jan 15, 2007 | 09:16 AM
ontheline's Avatar
would i have to do all that to bump the compression up or would valves just be fine?
Old Jan 15, 2007 | 10:45 AM
gibsanez's Avatar
Default Re: (ontheline)
No you don't have to do all of that, the c5 has a fairly high static CR as is. Search some info on flat faced valves and look into decking the block or milling the head. Have any engine shops nearby you can drop in to?
Old Jan 15, 2007 | 07:06 PM
ontheline's Avatar
anyone knows if the valves that come with the mx22's will raise my compression high enough?
Old Jan 15, 2007 | 07:42 PM
bambam's Avatar
m22x's will be fine in a jdm c5.
Old Jan 16, 2007 | 07:23 PM
ontheline's Avatar
anyone have the mx22 in there type r motor?
boy_hapon
Dec 2, 2005 06:38 AM
1999all_motoR_teg
Jul 31, 2005 06:21 PM
.nate
May 6, 2005 06:26 AM
PirateMcFred
Jun 17, 2004 09:23 PM
red91g2
Mar 3, 2003 12:12 PM
