cluster and climate control lights work till car warms up?
Old Jan 14, 2007 | 07:35 PM
OPTION2ek V.2's Avatar
Default cluster and climate control lights work till car warms up?
just bought an eg and i noticed my cluster and climate control lights stay on but when the car warms up the lights go out.i also notice sometimes my speedometer needle jumps somtimes when im driving..anybody have the same problem or if someone could help me that would be great.thanks guys in advance
Old Jan 14, 2007 | 07:40 PM
I Shot 50 Cent's Avatar
Is there a chance that the "warming up" part is a coincidence and the bulbs are loose? So when you're driving around (car is warmed up by then), you're hitting a bump and the lights are going out?
I say this because it's happened to me. When I started the car, my Si cluster worked fine but after I drove a bit the lights would go out. I replaced the bulb and made sure it was secure..and things have been good.
Old Jan 14, 2007 | 07:43 PM
B18CivicEH2's Avatar
Default Re: cluster and climate control lights work till car warms up? (sc300)
yea...make sure your VSS is on tight...i had the same prob with the jumping speedometer and i unplugged the VSS sensor and replugged and it worked..
naw im not even driving.it does it when its parked.thanks for the reply
Old Jan 14, 2007 | 07:44 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sc300 &raquo;</TD></TR><TR><TD CLASS="quote">naw im not even driving.it does it when its parked.thanks for the reply</TD></TR></TABLE>
I see, thats weird man.
Sorry I couldn't be of more help, but I'm definitely interested in seeing exactly what is causing the problems. I wish you luck figuring it out, and please keep this thread updated when you can.
Old Jan 14, 2007 | 08:14 PM
Default Re: cluster and climate control lights work till car warms up? (I Shot 50 Cent)
thanks guys..sorry but where is the vss sensor located at?
Old Jan 14, 2007 | 08:20 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sc300 &raquo;</TD></TR><TR><TD CLASS="quote">thanks guys..sorry but where is the vss sensor located at?</TD></TR></TABLE>
I believe the Vehicle Speed Sensor is located on the transmission housing. I'm not certain though. If he does not respond to the thread soon, PM B18CivicEG and he should know the answer.
Old Jan 14, 2007 | 08:27 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Shot 50 Cent &raquo;</TD></TR><TR><TD CLASS="quote">
I believe the Vehicle Speed Sensor is located on the transmission housing. I'm not certain though. If he does not respond to the thread soon, PM B18CivicEG and he should know the answer. </TD></TR></TABLE>
yea...thats correct...its on the Tranny..should look like this.....its located directly under the Throttle Body
here you go... its #8 & 9
here you can see it on the right side of the tranny which is the closest side to the firewall
Modified by B18CivicEg at 9:37 PM 1/14/2007
Old Jan 14, 2007 | 08:42 PM
Default Re: cluster and climate control lights work till car warms up? (B18CivicEg)
thanks guys ill try it tomorrow.hopefully my bulbs and the vss plug is loose.
Old Jan 14, 2007 | 08:47 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sc300 &raquo;</TD></TR><TR><TD CLASS="quote">thanks guys ill try it tomorrow.hopefully my bulbs and the vss plug is loose. </TD></TR></TABLE>
yea, just unplug theVSS and plug it back on pretty tight...should work
Old Jan 19, 2007 | 06:09 PM
s2ook's Avatar
My speedo suffered the same erratic behaviour for quite a few years - usually on long journeys. It has now ceased working altogether. Could this be a faulty connection or is it more likely the VSS has now taken a turn for the worse? It's throwing an ECU code too (17). I remember a Honda bulletin being issued about the engine wire harness rubbing on the intake manifold bracket so I may check this out too...
Old Jan 19, 2007 | 06:44 PM
Default Re: (s2ook)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s2ook &raquo;</TD></TR><TR><TD CLASS="quote">My speedo suffered the same erratic behaviour for quite a few years - usually on long journeys. It has now ceased working altogether. Could this be a faulty connection or is it more likely the VSS has now taken a turn for the worse? It's throwing an ECU code too (17). I remember a Honda bulletin being issued about the engine wire harness rubbing on the intake manifold bracket so I may check this out too... </TD></TR></TABLE>
https://honda-tech.com/zerothread/1171263
code 17 is for your VSS.
check if its plugged correctly or try a new VSS....
Old Jan 19, 2007 | 06:49 PM
s2ook's Avatar
I have an JDM SiR del sol with auto transmission - is the VSS a universal item or is there a different one for this tranny?
Old Jan 19, 2007 | 08:00 PM
Default Re: (s2ook)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s2ook &raquo;</TD></TR><TR><TD CLASS="quote">I have an JDM SiR del sol with auto transmission - is the VSS a universal item or is there a different one for this tranny? </TD></TR></TABLE>
im not sure how it is on a Automatic but im pretty sure its the same...take a look and/or run a search if you still having problems..
andrew.eg8
11
Sep 22, 2016 05:02 AM
aleks777
Feb 4, 2016 08:52 AM
SPOOLINmatt
Mar 31, 2008 09:51 PM
Nural
Oct 25, 2006 08:00 AM
JDM_EK_wanabe
Sep 28, 2006 02:03 PM
